Cruise control over redlines engine!!
Old Jun 28, 2007 | 06:06 AM
orvillespooner's Avatar
orvillespooner
Has anyone seen this?
2006 MCC stick
When on CC and disengaging it with the I/O button and at the same time pressing the clutch pedal, you can get a condition that causes the engine to go over redline controlled by the cc!!! Only way to stop is to press the brake pedal.
Old Jun 28, 2007 | 06:10 AM
Loony2N's Avatar
Loony2N
Hardly seems like a mystery to me. It takes a moment for the cc to disengage. If you put in the clutch at any speed, the revs will go up significantly. However, after a slight delay over redline, the engine management system should cut back power to bring it under redline.
Old Jun 28, 2007 | 10:11 PM
PenelopeG3's Avatar
PenelopeG3
Yeah, the ECU programming seems to have a few conditions for which the engineers didn't plan. On the MCSA, if you give it full throttle to the point where you activate the click down on the auto trans, it won't upshift. It will keep revving till you take your foot off the gas. Pretty dumb...
Old Jun 29, 2007 | 05:05 AM
rhawth99's Avatar
rhawth99
On every stick shift car that I have ever owned, when the clutch is depressed, the cruise control immediately disengages.
Old Jun 29, 2007 | 05:40 AM
Loony2N's Avatar
Loony2N
If you activate the "click" it's supposed to downshift, not upshift, which, of course will increase revs. But I would imagine the computer would prevent or limit over red-line.
Old Jun 29, 2007 | 06:39 AM
Baron Ken's Avatar
Baron Ken
The '88 Honda Accord I owned at one point would disengage the CC when the clutch was pressed, but apparently it was slow as it too would rev the engine briefly (not even close to redlining though).
David.R53
Sep 1, 2015 06:49 PM
Zettinger
Aug 25, 2015 04:04 PM
makg
Aug 21, 2015 02:49 AM
PatrikKN
Aug 5, 2015 09:10 PM
