Fluid inside car??
Old Jun 25, 2007 | 07:04 AM
tri650's Avatar
tri650
Fluid inside car??
I just noticed that I had something dripping from the driver side area - right above the clutch pedal. There was a small pool of some type of oily substance on the floor mat - looks like it had dripped down from near the firewall.
I did notice when I drove it last week that the clutch pedal was sticking at initial engagement - like it was hung up on something. I took a quick look this morning and could not tell. Drove it and everything was fine.
Any ideas?
Old Jun 25, 2007 | 08:35 AM
rhawth99's Avatar
rhawth99
Sounds like fluid leaking from the clutch cylinder. Is the fluid level down any? If still under warranty, I'd take it in to have this fixed quickly. I believe the clutch cylinder uses brake fluid which is nasty stuff as far as staining and removing paint. Good luck with it.
Old Jun 25, 2007 | 08:37 AM
kapps's Avatar
kapps
Definitely sounds like the clutch slave cylinder. Get it to the dealer before you loose the clutch.
09R56
Nov 16, 2022 10:49 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
Kahnfucious
Aug 15, 2015 08:43 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
