Where the heck is the clock???
Old Aug 4, 2007 | 02:19 PM
greenmonster's Avatar
greenmonster
I recently purchased a 05 MCS with the Nav System and can't seem to find the clock. The threads I've read say either on the speedo or by the map light but nothing is there. Since the Nav is where the Speedo normally is situated do I not have a clock? The car has a build date of 07/04 if that helps.
Old Aug 4, 2007 | 02:33 PM
ucbrother's Avatar
ucbrother
Just wait a little bit. Birdman or Robin Cassidy will SURELY chime in soon and save the day for you!
Old Aug 4, 2007 | 02:49 PM
Edge's Avatar
Edge
AdMINIstrator
On 05 & 06 MINIs, the clock is in the speedometer (in the digital part at the bottom). Even if you have Nav, it's in your (smaller) speedo that is attached to the steering wheel, next to the tach.
It shares space with your tripmeter. Just push the reset button briefly (i.e. don't hold it down, that just resets the tripmeter) and it will flip over to clock mode. To set the clock time, hold the button (the same one) in, and the hours will start blinking, after which you push the button advance the hours... to get to minutes, pause and wait.
It's really not that difficult, I'm probably overexplaining it.
Old Aug 4, 2007 | 02:55 PM
ucbrother's Avatar
ucbrother
The two NAM members I mentioned have a lot of experience with the built in NAV systems. I just figured they could help.
Old Aug 4, 2007 | 03:22 PM
Edge's Avatar
Edge
AdMINIstrator
Ahh OK. Well, they aren't the only ones... although my own experiences are all with the 1st Gen factory Nav. Since greenmonster at first posted in the 1st Gen Coupe Talk (before I moved it here), I figure he has the same setup I do. If I'm not mistaken, both Birdman & Robin Casady have R56s, which use a completely different Nav system.
Old Aug 4, 2007 | 03:42 PM
ucbrother's Avatar
ucbrother
I believe you are correct on both counts. Anyway, it looks like you have provided plenty of assistance for greenmonster.
Old Aug 5, 2007 | 06:59 AM
greenmonster
Edge, thanks for your help. Since the time wasn't programmed when I got the car the PO obviously didn't know how to do it either.
cub4bearindiana
Oct 2, 2015 09:45 AM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
rustof
11
Sep 25, 2015 10:35 AM
daviday
Sep 25, 2015 01:31 AM
BadgeFTW
15
Sep 20, 2015 11:39 AM
