New owner with a question.
Old Aug 7, 2010 | 08:55 AM
zeppo's Avatar
zeppo
After almost a year of looking finally found a Mini for me.Its a 2005 with only 22000 miles.Now after only about a month the service engine light is on.Everything seems to check out OK.Any suggestions beside take it in for a wallet cleaning?
Old Aug 7, 2010 | 10:36 AM
oldtruckpainter's Avatar
oldtruckpainter
Bring it to Auto Zone or some place like it that does a free scan of your car for trouble codes. Then afterwards you can disconnect the battery negitive cable for a few minutes. This will clear any codes stored in the computer. Then hook the battery back up. If the check engine light does not came back on when driving , then it was nothing to worry about. If it comes on again. It's time to see a mechanic.
Old Aug 7, 2010 | 11:02 AM
ricbow's Avatar
ricbow
service light usually means oil-filter air-filter cabin-filter & wipers
Old Aug 7, 2010 | 11:25 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Some places change the oil and filter and neglect resetting the Service Interval clock. If possible, check where purchased and see when it was changed last.
If you are like me, I just purchased what I needed and did it myself regardless...there are some DIY threads here too as the filter housing can be difficult at times. Cross threading of the cap and tearing of the O ring are common issues.
If you use aftermarket filters you are taking your chances. They sometimes have poor mfg tollerances and/or bad rubber O-rings ultimately causing your new oil to be dumped out on the tarmac at first start up or worse, 5 miles down the road.....as a rule we stick with MANN or OEM filters whenever possible....
Again, check the various threads here on a search.
And good luck with your new MINI
Old Aug 7, 2010 | 01:19 PM
Suzanne's Chili Red S's Avatar
Service engine light or maintenance counter?
Old Aug 7, 2010 | 09:46 PM
ricbow's Avatar
ricbow
i downloaded instructions on how to re-set service light on mini mania web sight. took some time but it worked....
Old Aug 8, 2010 | 03:43 AM
zeus7625's Avatar
zeus7625
From: So far south in AL, one more step and I'm swimming (in oil)
There seems to be a little confusion on the thread as whether it is the SES light or the maintenance light for oil service.
If it is the SES light on the column then "oldtruckpainter"s suggestion is a good one.
Did you recently fill up and not close the cap securely? That will trip the SES light. (Not that its ever happened to me but "a friend" of mine told me about it)
iclancy82
Jan 2, 2021 08:59 PM
tacticalbacon02
NEO Miniacs (Mini NEO)
Oct 4, 2019 07:18 PM
Grizld700
Dec 30, 2015 10:47 AM
jacobj
Tires, Wheels, & Brakes
Oct 4, 2015 11:49 AM
Ryan Caballo
Sep 4, 2015 12:20 PM
