Problem with painted wheel arches?
Old May 18, 2004 | 01:58 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
I think there's an inherent issue with the front wheel arches. Where the clips snapped into place, the dimples (small depressions) are visible on the arch. Normally, they are not as noticeable on the black mat-finished arches. However, when painted, the dimples are enhenced and quite pronounced.
For those with painted arches, do you notice the same problem?
_________________
Old May 18, 2004 | 10:30 AM
kenchan's Avatar
kenchan
uh oh... do you have a pict of this?
Old May 18, 2004 | 10:39 AM
kazlot's Avatar
kazlot
I think there's an inherent issue with the front wheel arches. Where the clips snapped into place, the dimples (small depressions) are noticeable on the arch. Normally, they are not as visible on the black mat-finished arches. However, when painted, the dimples are enhenced and quite pronounced.
Well shucks, now you went and told!
It appears that it is a common problem after painting. It is on mine.
Hope that helps...
_________________
03 BRG/ W Works MCS
Old May 18, 2004 | 10:41 AM
dcsmd007's Avatar
dcsmd007
It's not a big issue! The dimples are only visible upon close inspection. Before installing the arches, they're perfectly smooth. It's the pulling force of the clips creating the small depressions once installed.
I've seen them on other MINIs with painted arches. Oh, well!
Old May 18, 2004 | 11:08 AM
kenchan's Avatar
kenchan
I guess it's just a 'characteristic' of that mod.
wkp1219
Nov 13, 2015 07:52 AM
FLYM1N1
Aug 16, 2015 01:15 PM
messyjesse96
Aug 12, 2015 05:51 AM
Dashdog
Aug 10, 2015 06:17 AM
O4mcs
Aug 6, 2015 05:42 AM
