Engine Coolant
Old Jul 6, 2004 | 05:35 PM
JZBIGZ1's Avatar
JZBIGZ1
Engine Coolant
Where can a person get engine coolant from, other than from the dealer for a 04 MCS.
Old Jul 6, 2004 | 06:11 PM
kenchan's Avatar
kenchan
I would only use coolant that is made for aluminum motors and is anti-corrosive.
I use subaru coolant, actually....since I have a gallon bottle sitting around
for my other car. :smile: make sure you mix 50/50 with distilled water.
Old Jul 7, 2004 | 06:47 PM
JZBIGZ1's Avatar
JZBIGZ1
Did you drain out everything or add too? I'm looking to add to the coolant overflow tank. It's a little low.
Old Jul 8, 2004 | 07:14 AM
kenchan's Avatar
kenchan
I just added more. Add when the engine is cold, up to the middle mark
between Max and Min and you're all set. :smile: I check my coolant at least
once a month to be sure while I check my oil level.
Kimolaoha
Jul 5, 2023 01:04 PM
W0TM8
Dec 19, 2019 07:50 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:49 PM
tylewis
Aug 18, 2015 06:53 AM
