Anyone using NGK Copper Plugs?
Old Aug 11, 2004 | 08:59 AM
d2mini's Avatar
d2mini
part number? gap? torque?
Thanks!
Old Aug 13, 2004 | 03:26 PM
d2mini's Avatar
d2mini
anyone using ANY copper spark plugs???
So cheap so and so heat efficient compared to platinum! I can't believe no one has any...
Old Aug 13, 2004 | 03:32 PM
goldcountrymini's Avatar
goldcountrymini
If I am not mistaken... doesnt the Mini come with NGK stock???
Old Aug 13, 2004 | 03:38 PM
Uncle_John's Avatar
Uncle_John
Fitment in a JCW car is NGK BKR 7 EQUP. Don't know what material the electrode is . . .
Old Aug 14, 2004 | 08:46 AM
d2mini's Avatar
d2mini
OEM are platinum.
Old Aug 18, 2004 | 05:06 PM
JoeDentist's Avatar
JoeDentist
I've used NGK plugs since the 70's when I bought them for my air-cooled VW engine. The copper "heart" was supposed to run cooler. I have never had any kind of plug failure in all these years. I consider them every bit as good, if not better than Champion or AC, which are the U.S. standard for spark plugs.
Back then you had to change plugs every 10,000 miles or so. Now, with electronic ignition allowing larger gaps and no mechanical points, plugs can be rated to run as long as 30 - 60 thousand miles before requiring a change out, so you might only need to actually change plugs once or twice while owning the vehicle.
Filmy
15
Jun 6, 2023 06:27 AM
patsum
26
May 29, 2021 06:29 PM
CRC
Sep 14, 2015 07:27 AM
Emnotek
Sep 11, 2015 04:16 PM
Sep 2, 2015 09:05 AM
