Dangerous Situation
Old Jun 7, 2004 | 12:54 PM
aa3jy's Avatar
aa3jy
Dangerous Situation
I've got a problem..appearently the local dealer says they can't fix it. I have a very steep hill I have to climb before entering heavy traffic in the mornings. A continued problem with poor cold throttle response (acts like a choke is stuck open when cold-in a carborated engine) ..as a result I have to rev the engine and slip the clutch at an abnormal high RPM inorder for the car to move or the car will stall out under normal throttle response.
I've had the car in at the local dealer (Otto's BMW,West Chester,Pa.) and now the service adviser says that they can't fix it.. Is this a response that all of you would accept? They originally said they down loaded ver.38 and after several phone calls to them..they admitted that ver.38 isn't available and that they reloaded ver. 36 back in. Obviously they never checked the following morning that the problem(poor starting and cpoor cold throttle response) was fixed..they just hande it over to me..works fine with a warmed up car.
I find this unacceptable as far as the service that was performed or lack there of and the answers that I was given.
Opinions and thoughts would be most appreciated. FYI..I have emailed my concern to MINIUSA
Old Jun 7, 2004 | 01:03 PM
Moorlockx's Avatar
Moorlockx
"Can't fix it" is never an acceptable reply for a car that's still under warranty. You could try another dealer if you have one within driving distance. A second option might be to check out the regulations for your states lemon law (if there is one). Here, if the car's not fixed after the 4th attempt it can be lemoned out.
Old Jun 7, 2004 | 01:42 PM
kenchan's Avatar
kenchan
Would the car work better if you let it idle for a couple of minutes before
you enter that hill? At least for the time being?
Old Jun 7, 2004 | 01:44 PM
countrym's Avatar
countrym
You should certainly get V38 as soon as it's available. The word on the street is "June."
I also agree that finding a different dealer to service your MINI would be a good idea, if it's possible. The quality of service seems to vary widely from dealer to dealer.
Old Jun 7, 2004 | 05:19 PM
Ryephile's Avatar
Ryephile
Doesn't sound to me like there is a problem.
Very steep hill + car with little low RPM torque = big clutch slip to get it up the hill.
Do you have an MCS; how about a 19% pulley?
Old Jun 7, 2004 | 05:27 PM
supersulli's Avatar
supersulli
yeah, from what I've heard, these cars need a lot of coaxing on steep hills. Even those editors from motortrend said they stalled their long term MCS a couple of times when starting up on some hills. I assume they are great drivers, since they work for motortrend
Ryan
Old Jun 7, 2004 | 05:45 PM
Samtrak's Avatar
Samtrak
if by coaxing you mean keeping the RPMs high, the so be it. its more fun that way anyway!
Old Jun 7, 2004 | 09:25 PM
Barnabas's Avatar
Barnabas
The problem is that clutch wear will be higher than normal.
Old Jun 7, 2004 | 10:25 PM
Sullivan'sDaddy's Avatar
Sullivan'sDaddy
Originally Posted by aa3jy
...I have a very steep hill I have to climb before entering heavy traffic in the mornings. A continued problem with poor cold throttle response (acts like a choke is stuck open when cold-in a carborated engine) ..as a result I have to rev the engine and slip the clutch at an abnormal high RPM inorder for the car to move or the car will stall out under normal throttle response.
Starting from a dead stop on a steep hill, I rev the engine to at least 2k and gradually ease off the handbrake. See if that works, if you haven't tried it already.
Old Jun 8, 2004 | 08:33 AM
silver-mini-s's Avatar
silver-mini-s
I know this is still a large debate but try installing the M7 "Device". It worked for me on the low RPM start ups.
Old Jun 8, 2004 | 10:32 AM
aa3jy's Avatar
aa3jy
Poor starts and cold engine throttle response--Dangerous situation
This is a known issue appearently..and ver37/38 is suppose to fix this issue of poor starting and cold engine throttle response(acts like a choke is stuck open in a carburated engine)..but my dealer says they don't have this version(s) to fix this issue.
That is what I'm referring to and to overcome this problem ..I have to rev the engine much higher to over come poor response at the lower RPMs to prevent any stalling/stumble..apearently from what I'm hearing it's a result of the change over from our winter gas to summer gas in this region of the N.E.
Doc Pain
Mar 10, 2021 04:50 AM
Shomare
39
Oct 19, 2015 03:33 PM
dutchhome
Sep 30, 2015 07:17 AM
Chiro444
Sep 22, 2015 02:31 PM
