DIY instructions to replace A/C Condenser?
Old May 9, 2005 | 06:48 AM
mikealie's Avatar
mikealie
Hi. Does anybody know how to replace A/C condenser? Is this an easy DIY task? Thanks.
Old May 9, 2005 | 08:42 AM
rataha's Avatar
rataha
The hard part is dealing with the freon
Old May 9, 2005 | 09:10 AM
CoryB
The condenser replacement isn't really too bad.
It's the R-134 evacuation, vacuuming and recharging that's the problem.
You should probably take this one to a shop (not something I recommend often...)
Old May 10, 2005 | 06:34 AM
mikealie's Avatar
mikealie
If the condenser was punctured, do I need to do the vacuuming, etc? Or can I replace the condenser and bring it to a shop to have it charged?
Thanks.
Old May 10, 2005 | 06:40 AM
haskindmh's Avatar
haskindmh
A vacuum will have to be put on the system to remove any air and water vapor that is in the system. If the system has been open to the atmosphere it may also ne neccesary to "flush" the system to remove any conatminants. The system will then need to be charged with the proper amount of freon. The "proper amount" is critical! It is no longer acceptable to just charge it until it is cold. This job is best left to someone with the tools and knowledge to do it right.
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
thebordella
Aug 31, 2015 01:37 PM
damncajun
Aug 17, 2015 08:25 PM
Red Raven
Aug 11, 2015 04:48 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
