V41. upgrade?
Old May 26, 2005 | 01:50 PM
miniraider's Avatar
miniraider
V41. upgrade?
has anyone got this up grade...
it seems some people are getting this done...
my dealer has no idea what it is?
what does it solve....
any 411 0n the V41 upgrade out there?
thanks.
Old Jun 15, 2005 | 08:11 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Mine was flashed with v41 today. I pick it up tomorrow if it passes a dealer test drive. I'll report back when I can.
My dealer is BMW of Darien, Connecticut.
Old Jun 16, 2005 | 04:07 AM
blalor's Avatar
blalor
What's it supposed to fix?
Mine was at the dealer for a bad blow-off valve (hopefully) on Monday and Tuesday, but they made no mention of upgrading the ECU.
Old Jun 16, 2005 | 04:17 AM
Aqualung's Avatar
Aqualung
When I was at my dealer in May (MIN of Peabody) I asked about it and they said it wasn't for MCSs....Bilbo, what're you driving?
Old Jun 16, 2005 | 07:46 AM
astra's Avatar
astra
I had my MCS in the shop last week..
They flashed it with v41.
had a flat spot between 3800 and 4K..
got a new MTH map.. and it runs better than ever.. !!
Old Jun 16, 2005 | 08:02 AM
blalor's Avatar
blalor
You had the flat spot after v41?
What's the MTH map do to your warranty?
Old Jun 16, 2005 | 01:13 PM
Bilbo-Baggins
I drive an '02 MCS. I am picking it up tonight. I'll ask about that. See if I can find out what v41 was supposed to fix.
I had v39 previously, to fix the EPA recall. That introduced many problems on what had been a wonderful trouble free car. Until then I was still running v32, the original code that came with the car.
Old Jun 16, 2005 | 01:16 PM
Bilbo-Baggins
Was the flat spot a result of the flash? Or existing prior to the flash?
Old Jun 16, 2005 | 04:21 PM
Bilbo-Baggins
Just got back from the dealer. v41 did nothing for the off throttle herky-jerky show.
When I questioned one of the BMW/MINI techs about what v41 was supposed to correct he was not sure, but did tell me that v41 was for both BMWs and MINIs.
I am going to try and contact the SM, I was lead to believe that he would know if anyone would.
The start-up from a dead stop seems better, I will do more testing. I am pretty sure that the dealer reset the adaptive programing as all of the readouts of the OBC were zeroed out.
Tomorrow morning we'll see about the cold start and hard start problem.
Old Jun 17, 2005 | 10:28 PM
astra's Avatar
astra
tough to say.. the car started with v36 when i got it..
I have been running MTH maps since October of last year..
when the car was re flashed with v41. the flat spot appeared..
when I remapped the mth.. the problem went away.. had a very lovely track day today!!
Old Jun 18, 2005 | 06:09 AM
kenchan's Avatar
kenchan
btw, for those with v39+ have any issues with the original
stumble-off-the-line problem from years back?
Mine is a pre v34 (it's got a 06/03 birthdate) and other than the
"stumble" it drive perfectly fine. Im planning to take the car in for
an oil change this year and I think the dealer is going to make me
reflash the ECU for the recall.
The car doesn't stumble unless I enage the clutch
while the rev is a tad higher from a stop...so hasn't really been
an issue for me...I seldom experience it. if the dealer forces me
to update to v41, what should I expect in terms of performance?
it's sounding like the performance is going to degrade...
Old Jun 26, 2005 | 08:47 PM
jessminiS's Avatar
jessminiS
How can you tell the version?
How can you tell which version of software you have. I had my car into the dealer last week for key reprogramming. They said they do not flash the car every time because you can only flash an ECU about 9 times then you need a new ecu. Why should I care it's under warranty!! Can you get the version to come up on the screen on the tach?
JessminiS
Old Jun 26, 2005 | 09:40 PM
VRBeauty's Avatar
VRBeauty
stumble-off-the-line problem from years back? ..
The v.39 upgrade took care of my stumbling problem... '03 MC.
Old Jun 27, 2005 | 10:28 AM
kenchan's Avatar
kenchan
Thanks! I'll schedule my car in the near future. :smile:
molala
Oct 2, 2015 01:53 PM
Sep 10, 2015 10:52 AM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
