Recharging AC
Old Jun 10, 2005 | 08:02 PM
sjwass's Avatar
sjwass
Recharging AC
Does anyone know how to recharge AC. I find two valves on the left side of the car-one near the radiator and another closer to the engine bay. Which one do you add freon to?
Old Jun 10, 2005 | 08:14 PM
not-so-rednwhitecooper
recharge AC already???? even if you have an 02, its only 3 years old, it shouldnt go that fast!
dealer should do it for you to get the proper ammount of r134a in
Old Jun 11, 2005 | 01:22 AM
MotorMouth's Avatar
MotorMouth
I'm not saying you should do it yourself but the connection that comes with the recharge kit will only fit the correct one.
Old Jun 11, 2005 | 06:05 AM
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
If your car is still under warranty - definitely go to the dealer.
Also, be careful with DIY repair/recharge kits - many have stop-leak mixed in them which could seriously screw up your system.
Old Jun 11, 2005 | 06:44 AM
sonichris's Avatar
sonichris
always always always charge through the low side!! (if you take both caps off, it's the smaller one). now that you know enough not to blow your arm off, i do not recommend that you charge your own a/c unless you know what you are doing. simply adding freon will not make it colder. too much freon will increase the low side pressure and raise the evaporator temperature. the only way to properly charge an a/c system is to completely evacuate the system and charge it with the correct amount of 134a (by weight), OR monitor the pressures on low and high side with a pressure guage and use a performance chart to determine the proper pressures according to ambient temperature. short answer: take it to the dealer
StillK
R55 :: Clubman Talk (2008+)
Dec 7, 2022 08:19 AM
doug5g
12
Apr 17, 2019 12:44 PM
rikaro
Nov 24, 2015 02:05 PM
damncajun
Aug 17, 2015 08:25 PM
