SES light after installing pulley
Old Apr 13, 2005 | 10:47 AM
early_apex
What would cause the SES light to come on after installing a 15% pulley and colder plugs? The dealer says it is faulting due to improper crankcase pressure. I've got a HAI and a zip-tied bypass valve, but those mods have been in place for months.
The SES light came on a couple days after installing the pulley. It went out once on it's own, and once when the dealer cleared it, and both times came back on under heavy acceleration.
I'm going to put the bypass valve and HAI back to stock to see if that helps, but I'm not optimistic.
Old Apr 13, 2005 | 10:51 AM
RedBaronF2001's Avatar
RedBaronF2001
What was the error code (DTC)?
Old Apr 13, 2005 | 11:05 AM
early_apex
I don't know the specific error code, but the dealer said it was caused by bad crankcase pressure. Would having the specifc code help?
Old Apr 13, 2005 | 11:08 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
The zip-tied BPV can definitely cause a fault because the upstream pressure is lower than it should be. Cut that zip tie and hook up a VGS.
Still fault-free 2 months later. :smile:
https://www.northamericanmotoring.co...ad.php?t=38268
Old Apr 13, 2005 | 11:21 AM
early_apex
Thanks, I'll try that.
Old Apr 13, 2005 | 02:33 PM
early_apex
Undoing the zip tie fixed the SES on the way to the parts store, but the yo-yo is back. I'll get the VGS in later today and see what happens.
Alkaidovich
Jan 30, 2021 01:35 AM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
