Water on the inside of the windshield
So, has anyone else had an issue with water running down the inside of their windshield? I made the first stop of the day after my MINI had been melting off its white top. The normal water running down the windshield happened but when I hit the wipers to clear the water I noticed that the water was on the inside. Needless to say I have an apointment on Monday to have the dealer look into it. I was just wondering if others have had this issue. I have seen people in the forums complain of the moulding poping out of place but I wouldnt think a 2005 MC with just over 1k should be showing signs of any issues.
on
So I'm not surprised over windsheild problems.
Either you have a small animal with a weak bladder living under your headliner or your car was built on a monday or friday. Hopefully they will warranty your windshield rather than pull off the molding and squirt some goop along the top of the windshield. Because there may be a deformity in the glass contour.
MINI is in the shop today. The dealer called and said they can't do anything till tommorow when the glass guy comes. At least they are pulling the windshield and examining the glass to see if its bad. Then they are doing a complete reseal of the windshield. Good news is they are investigateing and fixing it properly instead of trying a quick fix. Bad news is im stuck with an ugly BMW 530i till they finish surgery. I wonder though if when the MINI's are sent across the pond if the windows are all the way up and the changeing pressures might pop the seals. Just a little speculation. Now I just have to remember what its like to drive a sedan again........
Sounds like somebody didn't do the seals right on your car, good luck on having them fix it.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
patsum
26
05-29-2021 06:29 PM
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
03-02-2016 07:10 PM
