Painting arches
Painting arches
What is the likelyhood that painting the arches yourself would turn out looking good? I found a website:
http://www.paintscratch.com/
that offers exact match colors for the mini in spray cans, as well as primers and top coats of automotive quality... what do you think? (I was also thinking of painting the aero grill inserts in my color (cosmos black) this should fit the bill nicely! :smile:
The dealer uses a special kind of paint to make it smooth on the arches. Because of the texture, they cannot use normal paint. So I am not sure how it would come out on the arches, that paint would be great for painting engine bay bits though. If you still want to try, I would buy some extra arches and try it on some that aren't on your car. That way if it doesn't come out good, no harm done.
To do it yourself, not unless you have the skills and equipment. A rattle can job will look like a rattle can job.
The grill should come out good regardless, no harm or foul if it doesn't- I'll just get another; the arches are another story, I bet they are expensive.
Painted arches
Do a search on the Roadfly X3 forum. Some folks on that site have painted the wheel arches on their X3's and you can learn what they did and see what the finished product looks like.
If you do it yourself don't sand the primer any smoother than 600. If you manage to spray it ok then the only problem is that the spray clearcoat is not catalyzed and is probably laquer. This makes it less durable and likely to be messed up by strong waxes and polish. I only recomend this if you see this as a learning experience and not a way to save money. Also, high build filler primer should be enough to fill the texture, you will regret getting involved with body filler. Good luck.
Umm... I don't think they are expensive, but I can't seem to find them anywhere (and it's way too late to call the dealer and ask)
Maybe someone else knows?
Maybe someone else knows?Joined: Feb 2003
Your very welcome!:smile:
vulkandino
Oct 31, 2015 08:29 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
