Map/BARO Sensor Errors
Old Apr 12, 2005 | 03:38 PM
JCampos's Avatar
JCampos
Hey smart people.... I bought this obd-ii reader at Kragens for $69.99 ($50 cheaper than the peake one and just as useful) to read and erase the engine codes I get.... Here are the 2 codes I read and what they mean...
P0107- MAP/BARO Sensor Low Input
P0108- MAP/BARO Sensor High Input
So, my question is.... what the hell does this mean? Everything seems fine... maybe a Unichip issue?
-jason
Old Apr 13, 2005 | 08:55 AM
PMC's Avatar
PMC
On one of the threads last year I remember reading that the P0107 code is normal if you have made some mods and that you should not worry about it. A search for this thread may contain some useful info.
Old Apr 13, 2005 | 01:43 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Your Unichip corrupts the signal from the MAP sensor so it may be the cause of those faults. I'd try removing the Unichip, clear the codes, and see if they return.
-jason
Old Apr 13, 2005 | 05:59 PM
JCampos's Avatar
JCampos
Ill just keep clearing em. I dun wanna go without my unichip
Old Apr 14, 2005 | 06:12 AM
andy@ross-tech.com
How do you know if the problem is definitely your Unichip? You may be doing damage to your engine by ignoring faults.
Old Apr 15, 2005 | 05:50 PM
JCampos's Avatar
JCampos
I didnt say I knew definitely...so, I did unplug it and sure enough it still happens... It throws the code(s) ONLY when at WOT and high RPM. Is this something I should be concerned with or should I try to replace the MAP sensor and see if it goes away?
shorenetworks
Nov 4, 2019 06:18 PM
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
