Replacement windshield wipers...
Even if they were, I certainly wouldn't recommend buying them. Mine crapped out in about six months. I have aftermarket blades now (Silblade) with a 5-year guarantee, and they work fantastically. It's like night and day. I'd shop around for something of higher quality than the OEM blades.
All you have to do is measure them (I think one is 18" and one is 19", but I'm not positive), and then buy the same size. The mounting mechanism is standard, and just about any brand of wiper will probably fit.
_________________
_________________
Location: Moved from Leesburg, VA to Oceanside, CA Nov. 2003
on
We've had ours replaced 3 times by the dealer - they just don't last very long - especially in areas like ours which got lots of snow last winter and lots of rain this summer and fall. I think we'll be looking into some others (not at the dealer) next time... :smile:
Chow!
Donna
donna@dcmetrominis.org
Chow!
Donna
I got silicone wiper blades on my MCS. They are a huge improvment over the OEM ones. They are more expensive (like $20 each), but definetly worth it. I have had silicone wiper blades on my Land Rover for over a year now, and they still perform great. They don't leave any streaks, they even wipe off mud and dirty water without a problem. Best of all, they don't freeze up and become useless in the snow. I got mine through http://www.silblade.com
_________________
Mel A.
you're talking to a kid
2003 Mini Cooper S-DS/B, pkg. 1,2,3, HK, TMS stage 1
1995 Land Rover Discovery-loaded, locked, lifted
sold the MGB, looking for a Triumph
_________________
Mel A.
>>guys my carbon fibr ones are comming next week, any install tips, are they easy
>>to put on. let me know if you have any tips or tricks on the install. thanks, kent
It'll be pretty straightforward. They'll include a few different types of common mounting hardware, one of which will fit the MINI. They do provide directions, but it's sort of obvious how to do it once you play around with it.
GB_Junkie
Mel,
Looks like the Silblades are the way to go. Did you replace the rear wiper too, or only the fronts?
p.s. saw your sig.
_________________
BLUBELLE - 2003 MCS IB /W Premium, Sport, Cold pkgs, Lapis blue interior, Magnecor wires, Alta Pulley, Moss Skid Plate, Chrome Trim Interior
Mel,
p.s. saw your sig.
_________________
I've been using Bosch blades on my cars for a couple of years. I get about a year out of them (depends on the amount of ice and salt in the winter), they cost about $10 a blade, and they're a snap to put on (literally!). I haven't seen the Silblades, but it seems like a cool alternative. $20 a blade? Ouch! But a 5 year warranty, eh? Hmmm...
Also, I believe that both of the MINI's front blades are 18" blades. The one in the back is pretty rinky-dink, and I don't know how replaceable it is. Anyone tried? Is there a changeable cartridge, or can only the blade itself be replaced?
>><snip> Does anyone use a glass coating, like rain-x.
Yep. I use Castrol AccuVision. It comes in a purple hand pump sprayer, if you are looking for it at your local parts store. I have applied it to the roof glass, the windscreen, and rear hatch glass. I just made a 377 mile run through fog and rain today. Aside from passing the occasional dirty-spray-spewing 18-wheeler, I only needed to run with the rear wiper on, and an occasional bump on the single-pass switch for the fronts. The water still beads over the entire surface of the windscreen.
This product needs to be re-applied more frequently than Rain-X, but it is a bit easier to apply. I have used both AccuVision and Rain-X, and both products make a marked improvement in wet-driving visibility.
To me, choosing between the two products boils down to deciding between regular applications (when I wash the car), or infrequent applications (twice a year) that require more effort (the Rain-X takes more time to buff off after application.) For my daily drivers, I use the AccuVision; for my "garage dwellers," I use Rain-X.
Definitly looking to replace mine with silicone type. I have had a silicone blade type dryer for when I wash the cars for over three years now and its still perfect. With four cars, I wash at least two every week. Probably get over three more years out of it.
BTW, its interesting how many of us have MGBs. Mine is a '69 roadster, restored to perfection three years ago and a daily driver til the MINI came along in June.
I have now had my wiper blades changed (4) times.
They are truly of.....inferior quality.
Free is good ...don't get me wrong... but their effectiveness is short lived.
These past few days with our 1st big snow storm and it's aftermath...were a horror show w/ the stock blades. :smile:
Those who have em...seem to swear by em...
So here goes yet another ...MINI purchase.
Peace,
D
Peace,
D
>>I was wondering if anyone has had any problems putting on SilBlades in the rear? The replacement arm does not seem to fit quite right and the blade itself does not fit in the OEM arm...
I am having this same problem, is there a trick, or do I just "muscle" it in??? Front ones fit fine, provided you aren't a bone-head. Took me like half an hour to put them on, once I got one on though, the other took 15 seconds. Ah well, live and learn
