Look what hit me in the foot while driving home tonight. Anyone know what it is?
Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
It's IS the clutch pedal return spring. Here is a huge-*** pic:
This is the view behind the knee bolster/parcel shelf (whichever you have), at the point where the clutch pedal hinges. This spring gives the 'over center' feel as well as the return. Should not be a big problem putting it back in, inless something broke, which is somewhat likely (especially at the plastic pedal arm). If it's under warranty, I'd take it back to the dealer if something has indeed broke or you dont want to fool with it.
Uhhhhhhhhhhhh, did the clutch get floppy after it fell on your foot?
I have had a problem with the clutch feeling notchy for a while. Dealer (MAG) says it is normal. So it felt ok. I will have a look under the dash. I would think it would be OK to drive. I have a dealer appointment Wednesday anyway.
dang, came here too late. I saw that return spring on the clutch pedal while I was working on moving my PIAA switch the other evening... oh well. :smile:
My spring also came off at one point. One of the connectors holding it in broke, and the dealer repaired it under warrenty. The clutch felt about the same without it, except for a slight click about halfway.
my clutch compression spring is off on one end... Anyone know if it's safe to drive with it not connected? I don't feel any difference in the clutch pedal.
