Physically removing battery from '06
Old Jan 18, 2010 | 04:14 PM
rocket503's Avatar
rocket503
Hello Forum,
It's time to replace my battery and I can't seen to figure out how to get the battery out of the box. There doesn't seem to be anywhere to get a grip on it? Is there a strap or something I'm missing?
The battery currently in place is the OE battery.
Thank you in advance for any help, tips or tricks.
Regards,
Chris
Old Jan 19, 2010 | 06:19 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Chris-
Yes, it's heavy. No, there are no handles. Remove any rings from your fingers! Disconnect vent tube. Disconnect neg. terminal and cover the neg. post with one of those plastic terminal covers or duct tape. Disconnect pos. terminal. Using a Philips Head screwdriver, unscrew the long hold-down strap screw, then remove the 10mm nut holding the hold-down strap and remove the hold-down strap. Push the battery leads aside. Wiggle battery slightly to the rear to clear the front lip. Grasp left and right sides of battery and lift it carefully up out of the box.
Installation is the reverse of the above.
Getrieben
Sep 12, 2024 07:03 AM
stevepsd
35
Dec 6, 2022 03:22 PM
eatsleepautox
Oct 30, 2015 06:46 AM
greekzilla
Aug 23, 2015 03:44 PM
Getrieben
Aug 15, 2015 09:09 PM
