PLZ HELP...Air Bag light is ON!!!!
Old Jan 12, 2010 | 11:57 AM
svldvc's Avatar
svldvc
Hello guys.
I bought my R53 (2006 Cooper S) with deployed DRIVER side AirBag.
I replaced the Airbag and bought TWO airbag Sensors. (1 for Pass side, 1 for Driver's).
Does anyone know where the airbag sensors are located on the Cooper?
I need to replace the sensors to shut off the AirBag Light.
Or do I need to replace more stuff than the AirBag sensors? Does anyone know?
All help and suggestions will be appreciated.
Thanks guys.!
Old Jan 15, 2010 | 05:38 AM
Densmini's Avatar
Densmini
You will have to remove the main sensor, which is located under the carpet and padding on the "tunnel" between the shifter and the handbrake. There are a number of companies that will reset it for you- I think mine was $ 50. I'll warn you that reaching it requires a pretty extensive process- if you do it by the book, plan on removing seats, center console/shifter, handbrake console, then lifting up carpet and foam. I cheated and left all that stuff in place, cut the carpet and foam, unbolted the module, then glued everything back together when done.
bneer
Jul 15, 2019 04:41 PM
nismo4life
Nov 4, 2015 09:18 PM
Aug 19, 2015 12:51 PM
