vibration while braking, vibration while Accelerating
Old Dec 29, 2009 | 07:38 PM
CARdiac's Avatar
CARdiac
I thought I would post this to help some people.
I was experiencing a vibration while braking, I first thought it was a warped rotor b/c a tire shop over torqued one lug, tightened 2 and left one loose... I replaced the rotor and it when away... but returned after a short time. I feared a bent hub. The weird thing was that if my car sat over night the steering wouldn't vibrate under braking until I had driven for a while.
A short time after the vibration showed up with braking I was getting a vibration with acceleration. It would happen under hard acceleration on the highway. The steering would vibrate under acceleration and stay when I lifted off the accelerator going away after a short time. I feared a bent drive shaft.
When I moved to DC I had to go to a dealer for some old botched warranty work from Fl. I was told my Lower Control Arm bushings were bad. I recently replaced the bushings and all my symptoms disappeared. Funny thing is that my wife's MINI has the same mileage and a dealer told us the LCA bushings needed to be replaced which we did. Her only symptom was the car would follow the smallest groove in the road.
I hope this helps someone else and saves them from replacing rotors, hubs or drive shafts.
Old Dec 29, 2009 | 07:48 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Good warning, It's not very common for the bushings to cause vibrations, but as you know it is possible and they should always be checked. And I don't need to say it but the Powerflex bushings make the best replacement.
Old Dec 29, 2009 | 07:56 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Good to hear Joel.
Old Dec 30, 2009 | 08:51 AM
CARdiac's Avatar
CARdiac
How can a lay person check the bushings? I have no idea what a good set or worn set looks like.... btw, I love the Powerflex
Old Dec 30, 2009 | 09:30 AM
AutoXCooper.com
You are right Joel, it can be hard to know if the bushings are bad until you get under the car and look and test them. I'm working on a video to make checking them at home easier to do.
molala
Oct 2, 2015 01:53 PM
Gremothra
Sep 9, 2015 08:42 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 3, 2015 03:01 PM
Ntety
Sep 2, 2015 08:39 PM
