Can somebody tell me where this oil is coming from
Old Dec 27, 2009 | 12:17 PM
Aphraidknot's Avatar
Aphraidknot
I have this oil leak and I don't know whether or not it is coming from this canister. BTW what is this canister (passenger side)
2006 MCS.
Attached Thumbnails Can somebody tell me where this oil is coming from-p1080733.jpg
Old Dec 27, 2009 | 12:23 PM
Some Guy's Avatar
Some Guy
It's one of your motor mounts. It's not engine oil it's fluid that is in the mount to dampen engine movement. This is not uncommon.
Old Dec 27, 2009 | 12:32 PM
iceckid's Avatar
iceckid
its common, and besides the mess not a huge problem. Time for a replacement, the choices are either another OEM, or a hard urethane unit.
Old Dec 27, 2009 | 01:12 PM
Aphraidknot
Thousand thanks too the both of you. I appreciate the quick reply.
Old Dec 27, 2009 | 05:06 PM
AutoXCooper.com's Avatar
AutoXCooper.com
bad mount you can replace with OEM one that will leak again or with a TSW mount
Old Dec 27, 2009 | 05:28 PM
tazio's Avatar
tazio
If you replace with the OEM mount, replace the lower mount also.
Old Dec 27, 2009 | 07:54 PM
wzabrouski's Avatar
wzabrouski
check out the new solid rubber mount from TSW mentioned earlier
Old Dec 28, 2009 | 01:01 AM
rkw's Avatar
rkw
With an '06, it would still be covered under warranty if the car is under 4 years/50K miles.
sevin
May 2, 2026 06:11 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Melvinyip
Apr 17, 2020 09:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
