ABS and Tires Lights Simultaneously
Old Jan 8, 2010 | 08:26 PM
Gromit801's Avatar
Gromit801
Ok, coming home from work, the ABS light and the flat tire light came on simultaneously.
I pulled off and checked my tires. No problem there, all showing the same pressure. Hit the reset button, but to no avail.
The book says my stability control may have gone south. Perhaps.
One mod I have is a MCAW circuit behind the toggle switches, so the DSC defaults to OFF when I start up. So I have in mind the possibility that the MCAW has malfunctioned. I will check into that tomorrow.
Question: Should both lights come on at the same time like that? And no flat tire to be found? And if the ABS has indeed malfunctioned, what is the remedy?
Old Jan 8, 2010 | 09:53 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Were they both on solid? If the tire pressure light comes on steady I think it is definitely bad.
Old Jan 8, 2010 | 10:07 PM
Gromit801's Avatar
Gromit801
Yes, both came on solid. Now in the past, the tire pressure light came on solid, and I found I did have a nail in the tire, so it worked properly. But this time the two lights came on together.
Old Jan 8, 2010 | 11:36 PM
Mister-Aandrew's Avatar
Mister-Aandrew
this means one of your abs sensors (aka speed sensors) is out. nuthing to worry about, doesnt effect your cars performance or what not, but get it replaced at soonest convenience
Old Jan 9, 2010 | 07:16 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
+1^
Old Jan 9, 2010 | 12:34 PM
Gromit801's Avatar
Gromit801
After thinking about it, that makes sense. Looks like an easy fix, but is there a way to determine WHICH sensor it is without having to replace each one with a test fit?
Old Jan 9, 2010 | 01:02 PM
TimL's Avatar
TimL
Find someone with a code OBDII scanner (e.g., ScanGauge); it should give you a code for the individual sensor.
Old Jan 9, 2010 | 01:14 PM
Gromit801's Avatar
Gromit801
Ok, I was hoping it would be something like that. I knew I should have put one on the xmas list, lol.
Looking n the back of the Bentley Manual pages of codes, I don't see any for the ABS sensors though.
Old Jan 11, 2010 | 01:33 PM
Mister-Aandrew
I dont believe that a Scangauge will read codes except for engine codes, so your gonna have to take it to get diagnosed to see which sensor it is. Im not sure if local autozones or pepboys still do those for free or not, but scanguages II's from my knowledge dont read those kinds of codes.
Old Jan 11, 2010 | 01:37 PM
TimL's Avatar
TimL
Thanks for the correction.... I wasn't absolutely certain.
My regular mechanic has a SnapOn Solus Pro scanner -- goes for about $3-4k -- which I believe is what he used to diagnose my recent DSC issues.
Old Jan 11, 2010 | 03:24 PM
NightFlyR's Avatar
NightFlyR
To the best of my knowledge the scanguage does not read it, it will be hard to find someone who has the proper tool, as even the BMW reader does not find these codes as I tried.
If you have the time, take each sensor off, clean the connection and put back on, good chance just some dirt is on there and throwing the light as that is what has happened to a few on here.
Good luck
Old Jan 11, 2010 | 10:46 PM
Gromit801's Avatar
Gromit801
Sounds like a plan.... to do when my back isn't spazzing out.
Old Jan 31, 2010 | 06:21 AM
kj4dbm's Avatar
kj4dbm
Both of my lights came on this morning, while trying to go up the driveway in snow. I will see if they will reset later today. I hope they go off but if they don't , I guess it will mean a trip to the dealer.
Dec 23, 2015 10:36 AM
Powershift
Aug 16, 2015 05:14 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
1964geo
Aug 10, 2015 06:22 AM
