Fuel Pump issues I think??
Old Dec 15, 2009 | 11:12 AM
tyde588's Avatar
tyde588
I have an 02 MC and recently had to replace the power steering pump. After replacing the psp it wouldn't start. It would crank but would not start. I checked for fire and had it. I know it's getting air so then I took off a fuel line and had my wife crank it and nothing came out. I then checked all the fuses and relays and determined that it must be the fuel pump that was bad. After replacing the fuel pump I still have the same problem. So now I am beginning to think the first fuel pump wasn't bad. Is there something I am missing or haven't checked? Please let me know.
Old Dec 15, 2009 | 12:22 PM
AutoXCooper.com's Avatar
AutoXCooper.com
check the electric connection on top of pump if that's good open the tank back up and check ALL the connections. Having done a few of them I know it's a PIA and it's easy to get a line off and or twisted. Check both side of tank.
Old Dec 15, 2009 | 01:07 PM
tyde588's Avatar
tyde588
I did all of that and still nothing! Now what?
Old Dec 16, 2009 | 04:27 AM
nicerideva's Avatar
nicerideva
it may be the fuel pump relay switch.
Old Dec 16, 2009 | 10:03 AM
WordIsBorn's Avatar
WordIsBorn
Most likely the relay. try and put 12 volts directly to the fuel pump. If it turns on, you have your answer!
09R56
Nov 16, 2022 10:49 AM
HaveATank
Sep 4, 2015 08:04 AM
scottrn
Aug 22, 2015 07:26 PM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
kpl
Aug 11, 2015 04:52 AM
