Plugs - 15% Pulley/CAI
Old Dec 22, 2009 | 09:47 AM
lou's Avatar
lou
I currently have the Denso IK22 but have been hearing talk of the Brisk plug manufacturer. For street use which would be best for upper Mid-West ( Chicago ) weather? Thanks..and also gaps required for the same?
Old Dec 22, 2009 | 11:51 AM
AutoXCooper.com's Avatar
AutoXCooper.com
The BRISK work great and I set them at .028
Old Dec 22, 2009 | 01:52 PM
lou's Avatar
lou
15%
Thanks - Do you have any in stock? .28" ??? I hope it is .028" and would you have ideal part number?
Old Dec 22, 2009 | 02:47 PM
ZippyNH's Avatar
ZippyNH
If you swap them yourself be very careful to tourqe the plugs down right...you might even want to use some locktight to keep them snug. A few people have had probems with plugs loosening, ang getting blown out....a very expensive problem.
Old Dec 22, 2009 | 02:52 PM
kapps's Avatar
kapps
Not sure I'd want to use loctite in the spark plug holes but checking the torque at oil changes is always a good idea. The heat of combustion would probably break down the loctite anyway.
Old Dec 22, 2009 | 03:23 PM
SlowGSX98's Avatar
SlowGSX98
+1 on checking the torque... I torqued mine to spec when I installed my brisk plugs and when I took my MINI in for a new head I was told the plugs were extremely loose, barely even finger tight.
Old Dec 22, 2009 | 05:32 PM
AutoXCooper.com
I just installed my last set this week.
Old Dec 22, 2009 | 06:30 PM
Crashton's Avatar
Crashton
Torque the plugs down, but do not put loctite on the plugs. If you do you may end up being sorry you did.
If you are worried about the plugs staying in there, check the torque at every oil change. I do on my MINI & have not found a loose one.
Filmy
15
Jun 6, 2023 06:27 AM
eliseo1981
Sep 18, 2015 10:40 PM
Accessory Products
Sep 11, 2015 08:01 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 4, 2015 03:56 PM
