squeaky door hinges
Old 06-26-2010, 05:20 PM
michele r53's Avatar
michele r53
michele r53 is offline
squeaky door hinges
What's the best lube for Squeaky door hinges
Old 06-26-2010, 06:49 PM
Justjones's Avatar
Justjones
Justjones is offline
Have you tried lubing the "slide" in between the door and the frame (at the front of the door/frame) with White Lithium grease? It gets dry and seems to cause squeaks. Other than that, Super Walmart sells a White Lithium grease spray that you can spray into the hinges, too, if needed.
Old 06-26-2010, 07:02 PM
solberg's Avatar
solberg
solberg is offline
Yep, the lithium spray worked for me
Old 06-26-2010, 07:39 PM
michele r53
I was figuring to use lithium grease but didn't.know if there was anything else out there. Thanks for confirming
Old 06-26-2010, 08:39 PM
nabeshin's Avatar
nabeshin
nabeshin is offline
Functioning Lunatic
I used generic all purpose grease from a tub that I had laying around. I smeared some onto the hinges and worked it in. No squeaks ever and it has a very smooth operation.
Fatherdeth's Avatar
Fatherdeth
Fatherdeth is offline
Yeah, use the lithium grease. If you run across a dry lubricant, it'll work too. It's a graphite type spray.
Old 06-26-2010, 08:40 PM
Fatherdeth's Avatar
Fatherdeth
Becareful, grease can attract dirt.
Old 06-27-2010, 04:49 AM
HRM's Avatar
HRM
HRM is offline
Gun lube works fine, but there are new high tech dry sprays that are waterproof. I can't remember name, but they are great for things like that (and power antennas on other cars)
Old 06-27-2010, 05:08 AM
michele r53
Any idea where to pick up the dry sprays?
gar56
11-15-2016 06:41 AM
jeri534
11-06-2015 01:40 PM
dutchhome
09-30-2015 07:17 AM
krohm
09-28-2015 12:16 PM
whowantstorace
09-27-2015 06:16 PM
Quick Reply: squeaky door hinges
