I have a situation.
Old Jun 1, 2010 | 05:37 AM
bmwstar1990's Avatar
bmwstar1990
I have a situation.
Finally... After four long months of looking, I have found the perfect R53 MCS so aptly named Mini Mojo. However, I have come across a problem. My navigator side door will not unlock the door from the inside. My co-pilot has to open the door by reaching his/her arm out the window and reaching the handle. I was wondering if this is a common problem. Any information will be helpful. I may just end up seeing way on Friday. Thanks in advance.
Old Jun 1, 2010 | 05:44 AM
Fatherdeth's Avatar
Fatherdeth
Are they pulling the handle twice? If not, you have to pull the handle twice to open it. If this does not work, then you have a problem inside the door, most likely a cable has popped off.
Old Jun 1, 2010 | 07:16 AM
bmwstar1990
Yes, they do that, and I have tried personally myself. Thanks for the info. I'll just have Way handle it Friday if he can fit it in his schedule.
Old Jun 1, 2010 | 08:34 AM
Cavalier Cooper's Avatar
Cavalier Cooper
Central locking system is broken.
Old Jun 1, 2010 | 08:45 AM
ZippyNH's Avatar
ZippyNH
Awesome shop!!
I've dropped in to see him a few times...great parts, and great info too when it comes time to "mod" your car if you want!!
Old Jun 1, 2010 | 09:28 AM
bmwstar1990
ugh.... great
Old Jun 1, 2010 | 10:57 AM
ZippyNH's Avatar
ZippyNH
It is likely just a broken cable.....don't freak out. The fact you can open the door from the outside, and it seems you are referring to opening the latch, so you can open the door...rather than un-locking it.....a locked door will not open from the outside! So something is messed up... but don't freak out!!
It is likely pretty minor...
Old Jun 1, 2010 | 11:16 AM
JIMINNI's Avatar
JIMINNI
My driver door just did this. My mechanic showed me a way to give it a temporary fix. We popped off the door panel, then you will see the cable running along the top. Roll the window down and remove the slack from the cable, keep holding the cable and now open the door normally from the inside, it should work. If it does and you want to save a few bucks, until you need to buy a new mechansim, drill a couple small holes in the sheet metal where you pulled the slack out, right in the middle of the door, and Ty wrap the cable down, so the slack is still pulled tight. This will work until then, did for me.
Old Jun 1, 2010 | 12:22 PM
bmwstar1990
Thanks Jim. I'm heading up that way now. I'll see you in a few if you are still there.
Old Jun 1, 2010 | 06:22 PM
jiminiS's Avatar
jiminiS
Nice hyper blue mini you got there newbie ,but can't help you with your
door problem. Anyway, Good to see you today and Congrats on your new ride. Lets start workin on some mods..... Jimmy
OctaneGuy
Apr 22, 2015 11:40 AM
OctaneGuy
Detailing 101
23
Nov 22, 2006 03:55 PM
optimuspryme
Nov 20, 2006 07:35 AM
JBravoMC
Nov 9, 2006 01:32 PM
