ABS DSC TPMS Lights all on, but my brakes work fine
my abs light came on which triggered my dsc light on also my TPMS light on my brakes seem to be working great but im afraid when winter comes i wont be able to move with out my dsc on.. any ideas what the issue could be?
also i took my seats out to remove my carpet, because my sunroof leaked and soaked it, how do i get my air bag light to go off everything is hooked back up properly
The ABS DSC TPMS lights are from a loss of connectivity with a wheel speed sensor. Whether the wires are the problem or the sensor is out, is something you will have to take a look at. Just get under the car, find the sensors, clean the plugs. Search for Trifecta for mucho threads on it.
Actually DSC should be off in the winter, anyway. It can sense a loss of traction from ice/snow, compensate and make things go from fine to in the ditch.
To to turn off the Airbag light, you need a special tool.....
The dealers have them, and sometimes they turn up on the market-place....I think PEAK makes one, they cost about $100.
Actually the ASC+T and or the DSC needs to be turn off sometimes to get moving...but it can do things with corner braking that a driver cannot do to keep the car on the road. Most folks run it during the winter and inclement weather, but turn it off during nice weather, or have it modified by their tuners to be a bit less intrusive.
It functions to keep you out of the ditch....so if the lights are lit, the system will not function as intended.
Since you had water in the car, I might wounder if the on off switches got wet and maybe corroded....some contact cleaner might help before you start removing the rims to get at and clean the sensors.....especially since you don't know which one has failed. Also did the BCM, on the right side get wet? If that area got wet...watch out....you might want to make sure the wiring harness going to it is plugged in tight....
Dec 23, 2015 10:36 AM
TunedGP
Oct 1, 2015 04:18 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
DWooderson
Aug 10, 2015 09:12 AM
