Power Steering Pump Fuse Loaction
Old Jun 20, 2010 | 08:12 AM
05Greenie's Avatar
05Greenie
Where is the fuse for the power steering pump fan for a 2005 R50.
Thanks,
Mark
Old Jun 20, 2010 | 03:29 PM
Mab01uk's Avatar
Mab01uk
Engine compartment fusebox
Note: The high current fuses FL1-FL5 are underneath (on the bottom) of the Engine Compartment Fuse panel.
High current fuses FL6-FL12 are on the right.
Fuses F1-F10 are on the left but are indicated in Mini wiring diagrams as F01-F010
FL4 100A Electric Steering control unit/Hydraulic pump
Fuses, Relays & Earth Points
http://www.minitorque.com/forum/f26/...th-points-533/
Old Jun 20, 2010 | 05:46 PM
minitech829's Avatar
minitech829
fuse box driver's side kick panel. it's the 2nd to last fuse in the last row (all the way to the right). 5 amp fuse. this blows when your steering fan locks up.
Old Jun 21, 2010 | 03:49 PM
05Greenie's Avatar
05Greenie
Thanks for the info....I'll check the fuse shortly.
But i think I have a bigger issue. Starting last week I noticed that if I drive my R50 for more than 1 hour, shut the car off then start it up after 5 minutes of rest the steering is very difficult to turn. I checked the power steering fluid level - fluid level ~ 1/8" away from the upper indicator - so that's fine.
I changed out the engine oil this weekend and I can spin the power steering fan freely, no binding or obstructions. So next is the fuse....one observation was ppprior to changing the oil I inspected the power steering area underneath the car and it it was wet with whatI would say was and oil substance, I an only guess it was PS fluid an yet my PS fluid resivoir was full. Could I have a leak in my rack-n-pinion???? Did I spell that correctly.
If Ithe car sits for ~30 minutes everything is fine, no issues with steering....any idea's.
Mark
Old May 21, 2013 | 06:07 PM
scottwrightF1's Avatar
scottwrightF1
Mark
I have a similar problem with my 2002 R50. Today the temp was like 25 degrees sunny and after driving for like 30 mins. The power steering was hard to turn, but it did not make any noise. I let the car cool down for like 30 mins to an hour and start it up. The steering went back to normal smooth till I turned the engine off. I just had the pump and fuel lines replaced less than 1000kms ago. I checked the fuel level and it okay.
I try to find the fuse "FL4 100A" from under the hood and I didnt see any??
What could the problem be?
Please let me know.
Thanks.
Old May 21, 2013 | 06:15 PM
Braminator's Avatar
Braminator
Here are all the fuses and relay locations
F1 5A Digital engine electronics control unit
F2 20A Digital engine electronics control unit/Ignition coil/Cylinder 1-4 fuel injection valves/Crankshaft position sensor (From K6300 87)
F3 15A Camshaft position sensor/O2 sensor before cat/O2 sensor after cat/Solenoid valve, fuel tank ventilation/Relay K19 control power (From K6300 87)
F4 15A Tank Leakage diagnosis pump
F5 5A Relay, engine cooling electric fan (From K6300 87)
F6 30A ABS/ASC/DSC control module
F7 30A Magnetic clutch for AC compressor via relay K19
F8 30A control power K69923 Relay, electric power steering pump cooling fan/Switch unit Heating & A/C blower
F9 20A BC1 (X11177 2) unit via I01136 and I01137 (Relay front wiper motor fast/slow and Relay front wiper motor on/off)
F10 15A BC1/Left fog/Right fog/Switch panel via K47
FL1 50A Feed to F14, F31, F32 (BC1,Heating & Air con blower)
FL2 50A Feed to F1, F2, F3, F4, F19, F20, F21, F22, F23, F24, F25, F26, F27, F28, F37 (BC1, steering angle sensor, clock, instrument cluster, navigation, on-board monitor, wash/wipe, horn, audio system.)
FL3 -
FL5 50A Feed to F15, F16, F17 (Sunroof, aerial antenna, rear wiper)
FL6 40A ABS/ASC/DSC unit
FL7 50A Feed to ignition switch
FL8 50A BC1 (X332 20) Headlight
FL9 50A DME unit and Switching unit 2-speed blower via I01135 (Relay electric engine cooling fan)
FL10 50A K416, Relay heated front screen
FL11 50A Switch unit, 2-speed blower heating & air con
FL12 50A BC1 (X332 17) Headlight
Passenger compartment fusebox
F1 30A BC1 (X332 3) power windows LH
F2 5A Steering angle sensor
F3 5A Digital clock/Outside mirror fold-in control unit
F4 5A BC1 (X254 27) Constant power
F5 5A Control module for instrument cluster/Diode (From Electronic immoblizer control unit)
F6 5A Brake light switch/Clutch switch module/Electronic immobilizer control unit EWS
F7 5A BC1 (X254 36)/Rain sensor
F8 5A Turn indicator/low beam switch
F9 5A Control module for instrument cluster
F10 5A Navigation computer/On-board monitor control unit/Radio control unit
F11 5A K119, Relay, rear washer pump/K5 Relay, front washer pump
F12 20A Ignition switch to heated seats
F13 5A Reversing light switch/CVT switch
F14 10A BC1 (X332 14) Constant power to interior/reading lamps
F15 20A Sunroof module control unit
F16 30A BC1/Rear window w/o antenna or Wave trap 1 w/ rear window antenna via K13/ Heated rear screen
F17 15A BC1 (X254 43)/Rear window wiper motor via I01142 (Relay rear wiper motor)
F18 5A Hall sensor driver & passenger buckle/Multiple restraint system (SRS system)
F19 30A BC1 (X332 7) power windows RH
F20 20A K96, Fuel pump relay 1
F21 10A Control module for instrument cluster
F22 15A On board monitor control unit/Navigation computer/Eject box
F23 20A K5 Relay front washer pump/K119 relay rear washer pump
F24 5A Electronic immobilizer control unit/Horn for antitheft alarm system EWS
F25 30A Headlight washer pump via K6
F26 10A Automatic transmission
F27 15A Radio control unit/CD Changer/Amplifier
F28 15A Volute spring/Right horn/Left horn via K2
F29 5A Heating and AC control module/Sensor interior temperature fan
F30 5A Instrument cluster
F31 30A BC1 via K4 (X253 23) Heating & A/C blower
F32 15A Front cigar lighter via I01151 (Relay cigarette lighter front)
F33 10A ABS/ASC/DSC unit
F34 10A Digital engine electronics control unit direct and via K96/Eng management main relay
F35 5A Mirror adjustment switch/Electrochrome rear view mirror/Windscreen washer jet heater/Outside mirrors
F36 5A K416, Relay Heated front screen
F37 20A BC1 (X332 1) Central locking
F38 -
F39 5A Alternator/Electric Steering control unit/hydraulic pump
F40 5A Control module for instrument panel/Switch panel/Steering angle sensor
F41 5A Park distance control unit/power to K69923, Relay fan steering control module/pump
F42 -
(MCS Only – Luggage compartment fusebox, MC/One direct battery feed)
F100 250A Feed to FL1, FL2, FL4, FL5, FL6, FL7, FL8, FL9, FL10, FL11, FL12, F1, F6, F7, F8, F9, F10, K6300
For Ref.
BC1 – Body Control Unit
Located behind kick panel – drivers footwell (UK) / passengers footwell (USA / Europe)
4 Connectors:-
X332 20 pin (green)
X253 54 pin (black)
X254 54 pin (natural)
X255 54 pin (blue)
IDs for Relays / Location
K2 Fanfare Horn relay / Passenger compartment fusebox
K4 Heater-blower relay / Engine compartment fusebox
Control: BC1 (X253 23)
Switch: M30/A11
K5 Relay washer pump front / Behind passenger compartment fusebox
K6 Relay Headlight washer / Passenger compartment fusebox
K13 Relay rear window defroster / Passenger compartment fusebox
Control: BC1 (X254 22)
Switch: Rear window defroster
K19 Relay AC Compressor / Engine compartment fusebox
K47 Front fog light relay / Engine compartment fusebox
Control: BC1 (X254 40)
Switch: Left fog light/Right fog light/Switch panel light
K96 Fuel pump relay / Passenger compartment fusebox
Control: A6000 (X60004 24)
Switch: M2
K104 Relay auxiliary water pump
K119 Relay washer pump rear / Behind passenger compartment fusebox
K416 Relay heated windshield
K6300 DME Relay
control: A6000 (X60004 16)
Switch: F02/F03/F04/F05
K69923 Relay fan steering control
Relay front wiper fast/slow / Engine compartment fusebox
Relay front wiper on/off / Engine compartment fusebox
Relay rear wiper / Passenger compartment fusebox
Relay cigar lighter / Passenger compartment fusebox
Body Earth Locations
E1 LH rear of engine compartment
E2 LH front of engine compartment
E3 RH front of engine compartment
E4 RH side of footwell
E5 LH door sill
E6 LH side of luggage compartment
E7 RH side of luggage compartment
E8 RH door sill
E9 LH door sill
E10 Behind LH rear window trim panel
E11 Behind RH rear window trim panel
Old May 21, 2013 | 06:34 PM
scottwrightF1
FL3 -
F38 -
F42 -
For Ref.
4 Connectors:-
X332 20 pin (green)
X253 54 pin (black)
X255 54 pin (blue)
Switch: M30/A11
Switch: M2
K6300 DME Relay
E5 LH door sill
E8 RH door sill
E9 LH door sill
I know it under the Engine compartment fusebox, but I said under the hood. I couldnt find the FL4 anywhere on the fusebox. Could it be a different year made for this model? My car built date is 07/2002.
Old May 21, 2013 | 06:42 PM
Braminator's Avatar
Braminator
1st check F39 5 amp fuse in the drivers side foot well fuse panel. In the engine compartment under the ECM is the FL4 100 amp fuse. You have to take the ECU and battery box out of the way to get to it. Hope this helps.
Old May 21, 2013 | 06:46 PM
Braminator's Avatar
Braminator
Old May 21, 2013 | 07:02 PM
scottwrightF1
Oh great, so it under the fuse box.
Will check it out.
Could there be any other problem beside the fuse?
Thank you.
Old May 21, 2013 | 07:06 PM
Braminator's Avatar
Braminator
Will check it out.
Thank you.
Yes. The pump is dead.
Old May 21, 2013 | 09:23 PM
scottwrightF1
I took out the battery and to check the fuse. The fuses looks okay. After I put the battery back in and connect the cables on the battery. I heard a weird whining noise then it stopped. Would that be the pump?
How can you be a 100% sure is the pump?
It weird I just put in a new pump not too long ago and it would fail already again?
Is there any other way to check the pump working?
Old May 22, 2013 | 12:07 PM
Good advice above. After you check the fuses like shown above, Check the connections on top of the pump, sometimes people when installing a new pump break the clip on the PS harness side when removal the top cable and then the male side works its way out.
PS Pump.
http://www.ecstuning.com/Search/32416778425KT1/
The Power steering pump does make a whine and when you turn the wheel the whine changes a little then returns I would make sure all your connections are on and tight to the pump since its on and off from what you mention. Inspect all electrical cable going to the pump.
Also did you have the fan changed out also. Since you are down there make sure the cable to the fan is tight and if you have the old fan ( I believe the original 2002 did not have the grille ) , it would be insurance with a new pump to replace.
http://www.ecstuning.com/Search/32416857718/
Thanks and hope that helps.
Old May 22, 2013 | 07:36 PM
scottwrightF1
PS Pump.
Thanks, I have tried all of your suggestions you have given me above.
I have tried to measure voltages at the three pin pump connector (x6975) that connects to the pump EHPS control module. I have not be able to read any voltage on any of the three pins? I am puzzled because fuse F39 and FL4 (100A) seems to be good?
The cooling fan is working okay and there is no whine noise from the pump.
Any suggestion?
Old May 23, 2013 | 09:27 PM
scottwrightF1
I retested the voltages from the three pin connector (x6975) again and is working. I must have had a loose voltage when testing the pin connector.
It seems all the wiring, fuses and cooling fan are working 100%. I also checked the steering rack boots and there is no leak from the pump fluid.
Last, there is no noise or vibration coming from the pump when the car is running. Should there be some noise and vibration from the pump?
Please let me know.
Thanks.
Old May 27, 2013 | 08:53 PM
scottwrightF1
Took the car to the dealer today. Turned out that the pump had failed again. They replaced the rebuilt pump that still had warranty on it and a free new cooling fan with grille.
This is my fourth pump replaced with only 97,900km on car. Two pumps was replaced by previous owner. I replaced the third pump myself not too long ago this year and now dealer installed the fourth pump today.
Weird, is that common for a very low mileage car pump to fail?
I ordered a new Underbody Paneling #51757201784 and Air Channel #51757201453 to have a better life on the pump.
Thanks.
Etrain
16
Aug 5, 2024 04:37 AM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
