R50/53 What tire size for new 17x8 wheels?
Old May 20, 2026 | 09:01 AM
IQRaceworks's Avatar
IQRaceworks
I’m swapping out my stock 17x7 (48et) wheels for some new 17x8 (35et) wheels. Currently, I’m running 215/45/17 tires on my oem wheels…..stock ride height, and no fitment or clearance issues at all.
Because of the offset on the new wheels, I should have some extra clearance between the strut and the wheel/tire, so I’m thinking about taking advantage of that and running a slightly wider tire.
Both a 225/45/17 and 245/40/17 are almost (+/- ¼”) the same diameter as the 215/45/17 that I’m currently running…..but the 225 is around ½” wider overall, and the 245 is around 1.4” wider overall. According to the tire fitment calculators I’ve used….even the 245/40/17 should clear the strut just fine.
This is a daily driver car that also hits some twisty roads on the weekend. Looking for a wider tire for a larger tire patch, and a better look…..but I don’t want to make the handling worse.
What should I go with? Stick with the same 215/45/17, go with the slightly wider 225/45/17, or max it out with a 245/40/17?
Thoughts?
Old May 20, 2026 | 09:12 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Because you are going from a 7" wide wheel to an 8" wide wheel, even though the offset is reduced, the clearance at the strut will be the same.
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
A 215/45-17 tire on an 8" wheel will be pretty square.
Old May 20, 2026 | 09:24 AM
IQRaceworks
Thanks! I like that wheel/tire calc better than the one I was using! If I can fit the 225 or 245 (assuming there is enough suspension clearance).....is there any advantage to going with those wider sizes?
Thanks for the reply!!
Old May 20, 2026 | 12:26 PM
ssoliman's Avatar
ssoliman
wider tires have more grip. as mentioned you will be limited by clearance on both sides
wider tires also have a different look. thats all about your personal taste
Old May 20, 2026 | 12:38 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Wider tires will give more grip, up to a point. If the wheel can't support the tire, handling will feel sloppy. On the Mini, you're going to be limited by clearance between the suspension and fender. Depending on ride height and camber specs, I'd wager 225/45-17 is going to be the biggest tire you'll fit on the car, without going with fender flares and cutting. I had rubbing on my lowered Clubman with 17x7 and 215/45-17 tires, and my alignment numbers were within OEM spec. I needed to bump to -2° camber in the rear and go back down to 205/45-17 tires.
Play around with that website to see what "might" fit. Measure everything around your car, and enter it into the calculator. Then play around with your desired wheel and tire choice. Keep in mind too that different tires will have different measurements, even if they might have the same size listed.
Old May 20, 2026 | 12:55 PM
ssoliman's Avatar
ssoliman
note you are going wider with the 8 inch rim. plus the lower et. that will push the rim even further outboard. it will be close
Old May 22, 2026 | 05:07 AM
MisterDangerPants's Avatar
MisterDangerPants
I've run a few sets of 17x8 ET35 on my R53, R50 and R52. I ran 225/45/17. After awhile the plastic arches wear down from the rubbing (or you can just file them down in advance).
Old May 22, 2026 | 05:58 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
If you're still riding on the stock springs and strut/shocks, fine but if the car is lowered, be careful what you choose.
Old May 22, 2026 | 06:03 AM
GotGrit's Avatar
GotGrit
Br Goodrich 215/45ZR17/XL is what I run on my 17x7.5 wheels. These rubbed on the plastic inner well until the plastic wore out enough. No more rubbing . The rubbing was only on the rear and I'm pretty low. (See for sale posting of my mini) They cover the lip with an added .5" so would be flush with a 17x8 I'd think.
user 837978240
Tires, Wheels, & Brakes
78
Jan 17, 2019 12:32 PM
duckdownman
May 7, 2018 08:55 AM
BSTINS
Dec 21, 2012 11:52 PM
pwnage
Jul 10, 2009 12:47 AM
k_h_d
Oct 14, 2006 04:58 PM
