Has anyone tried this PEAK Scan Tool R5-EMX
Old Feb 3, 2004 | 09:04 PM
DSA's Avatar
DSA
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Just want to know before I drop some coin as I live 360 miles from the nearest dealer. Also would it void my warrenty
Thank You in advance
Eric
_________________
So you make up with your lack of manhood with that big SUV huh?
Old Feb 4, 2004 | 11:14 AM
rwg's Avatar
rwg
I haven't used the tool for the Mini, but I have used it for my e36 bmw. It works easily, seems to be idiot proof as far as insertion goes, and I find it very useful. Especially when you start doing your own maintenance.
I don't know about the warranty, but I never had any issues with the M.
Old Feb 4, 2004 | 11:19 AM
Trippy's Avatar
Trippy
I would recommend the ELM-ISO from scantool.net
since it's much cheaper and can capture performance data,
but it requires a laptop computer to work.
Old Feb 4, 2004 | 11:25 AM
X2Board's Avatar
X2Board
I have one, works great, I was able to use it to prove the MINI tech at the dealer wrong, he swore my car had a broken valve spring, even though the tool said it was a fuel injector problem. Guess what, it was a bad contact on the injector plug.
X2
Old Feb 4, 2004 | 01:52 PM
asodestrom's Avatar
asodestrom
Do yo have one of these? It seems to be a great bang for the buck
Old Feb 4, 2004 | 09:52 PM
Trippy's Avatar
Trippy
I sure do.
Here are some graphs I captured using it. (I wrote my own software
to capture the data. Sorry about that)
Speed vs RPM:
Ignition advance vs speed:
Speed, throttle and fuel closed-loop:
Coolant temp:
Old Feb 5, 2004 | 09:05 AM
KiLO's Avatar
KiLO
Seems a lot cheaper, but does it do the same diagnostic type things that the other one does?
Thanks Trippy...
Old Feb 5, 2004 | 09:08 AM
KiLO's Avatar
KiLO
Nevermind, after being smart about it and reading the webpage, I found the answers... looks like a pretty good unit.
Old Feb 5, 2004 | 09:21 AM
Trippy's Avatar
Trippy
The disadvantage to the scantool.net product is that you need a computer to access the information.
The Peak unit is just plug-n-go.
You pay for that feature with dollars and not getting the ability to capture data.
Old Feb 5, 2004 | 10:43 AM
KiLO's Avatar
KiLO
Right.... Well, that unit looks very cool... I'm becoming interested in it now... I have been thinking more and more about how I need to start doing my own maintenance, and I do have a laptop that I can connect it to... Hmmm
Thanks!
Old Feb 6, 2004 | 05:51 PM
jmoser's Avatar
jmoser
MiniMania sells the Engine Scan Reset Tool for $130...appears it wil betat the Ebay sale....
http://new.minimania.com/web/SUBTYPE..._Inventory.cfm
Old Feb 7, 2004 | 05:29 AM
orvillespooner's Avatar
orvillespooner
That thing may be useful, but it doesn't look like it diagnoses the airbag system. Sometimes the airbag light could set and there really is no problem so it's back to the dealer.
Old Mar 2, 2004 | 11:48 AM
JaySnyder's Avatar
JaySnyder
Peake makes an SRS reset tool, but I don't know if it works with the MINI.
I bought one to reset the SRS light on my '94 BMW (which was on because I turned the key on with steering wheel off while diagnosing an instrument cluster problem.
http://www.peakeresearch.com/srstool.htm
As for the R5/EMX I would assume that it is the same in use as the R5/FCX that I have for my BMW.
It is very easy to use. Can read codes, clear codes, and reset oil and mileage service intervals.
I just with the SRS and FCX tool where all one tool, as they go on the same plug. For that matter, there is no
reason the FCX and EMX can't be the same tool, as 2001 and newer BMWs have the same diagnostics plug as the MINI.
Old Mar 2, 2004 | 07:40 PM
JaySnyder's Avatar
JaySnyder
I just heard back from Peake. They don't have anything for the SRS system on the MINI (yet).
Old Mar 5, 2004 | 10:45 AM
tornado's Avatar
tornado
So, is there anything like a VAG-COM device VW's use for the Mini or other BMW's? This lets you not only see and interpret the codes, but also lets you write settings back into the ECU (called "adaptation&quot. VAG-COM installs on a laptop and displays all the data on screens. It can also capture live data during test drives.
I'd sure like to be able to set the convinence options on the mini like DRL's, Key Fob controls of windows/locks, and all the other things without having to go to the dealer and pay $50 (required if you don't go to your car purchase location).
Mike.
Old Mar 5, 2004 | 10:55 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Not yet.
Old Mar 5, 2004 | 04:21 PM
tornado's Avatar
tornado
Hmmmm
Just give us VW VAG-COM owners a break on the price to access our Mini's as well and I'll be your first customer (or perhaps a Beta Tester???)
Mike.
>>Not yet.
Old Mar 5, 2004 | 09:33 PM
andy@ross-tech.com
http://www.ross-tech.com/vag-com/faq_4.html#othercars
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
daviday
Sep 25, 2015 01:31 AM
