Please help me ID Part Numbers for these
Old Apr 15, 2004 | 11:12 AM
FraserBonnett's Avatar
FraserBonnett
I have a three hour one way trip to the nearest Mini dealer, so before I go I want to make sure they have the parts I need in stock.
They are all related to the Intercooler cover:
First are the front Torx bolts:
Right
and left
Then, on the left side, the torx bolt sheared off inside the threaded pillar "thingy" and I seem to be missing a bracket bolt on the right:
and while I'm at it, how about the 2 nuts that hold the hood scoop in place (sorry no pic)
Thanks in advance if anyone can help with part numbers for these.
Old Apr 15, 2004 | 08:29 PM
Smokey's Avatar
Smokey
On your intercooler:
They don't break it down on where each bolt goes (front or back) but based on what I can see in your pictures and on the ETK I'm betting that the front screws are the shorter of the 2 listed in the ETK.
Short Torx Screw (M6x18) 17 517 519 975
The longer ones that go through the rear support are (M6x60) 17 517 519 974
The bolt that holds the support bracket is (M6x12) 07 130 782 486
There are really 4 nuts holding the hood scoop. 2 are labeled flange nuts (M5) 07 130 778 878 and the others are called expanding nut (no size listed) 07 130 666 714
At least that's what my ETK is showing, but the most current date I can look up is a Dec 02 model. Don't really think that they have changed the hardware, but never know.
Good luck
Old Apr 15, 2004 | 08:35 PM
FraserBonnett
smokey4, thanks a bunch. Just what I needed.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
absolutcamper
Aug 24, 2015 12:27 PM
nomar116
Aug 21, 2015 04:36 PM
xraycat
Aug 15, 2015 06:43 AM
