the alta intake....
Old Apr 17, 2004 | 02:03 AM
EDK13's Avatar
EDK13
I installed the alta intake juz now.... I found out tat there's impossible to screw the intake ( the red part) tight!!!!! is it normal?
pls help... I dun want the intake jux fall off while I m driving..
thanks ...
Ed
Old Apr 17, 2004 | 03:14 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You have a common problem with the alta intake.
The red filter doesn't attach to the ring on the intake box very well. It gets loose easily.
Get some alcohol and wipe the ring clean of oil which came off of the filter.
This allows the intake filter to be fastened tighter to the ring so that it doesn't slip.
The design fix for this would be a ring that is slighter wider so that the filter can tighten onto to it better.
Old Apr 17, 2004 | 03:34 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
I have Alta with no problem.
As minihune suggested, clean the contact area. Another thing to consider is to add a layer of thin weather striping for a tighter fit. :smile:
Old Apr 17, 2004 | 05:15 AM
MGCMAN's Avatar
MGCMAN
Another suggestion,
Take a pair of pliers and go around the ring on the intake box, gently prising up a section or three. If done properly, you will have no problem slipping the filter and it's tightening band over the box's ring, and it will allow sufficient change in diameter to get a tight fit.
Old Apr 17, 2004 | 06:39 AM
kenchan's Avatar
kenchan
I would also suggest wrapping the ring with 3M electric tape to get it meatier
after you degrease the ring.
Didnt have this problem on my Pilo intake.
Debi's Coop S
Dec 27, 2015 02:35 PM
vulkandino
Oct 31, 2015 08:29 PM
Joeygonz
Oct 4, 2015 09:25 PM
Debi's Coop S
Oct 3, 2015 07:49 AM
gnhovis
Sep 28, 2015 06:28 AM
