Quick questions about Version 36
Old Mar 13, 2004 | 09:28 PM
Arly's Avatar
Arly
I just had version 36 programmed. Here are a few questions:
-I noticed that my gas mileage is slightly less. Is this caused by the cold weather here in Michigan? I usually do not have my MCS out of storage by this time, but I needed to get the waterpump replaced.
-Will disconnecting the battery eliminate what was programmed? Could be a dumb question, but I wanted to make sure.
Thanks all,
ARLY
Old Mar 13, 2004 | 10:10 PM
Ryephile's Avatar
Ryephile
gas milage has dropped on some with V36 upgrade, and increased with others. There doesn't seem to be a definitive correlation. What is definite, is the winter-blend fuel (which seems to lower milage). Not sure when the changeover is to summer-blend.
No, disconnecting the battery yields no effect on flash memory. You radio settings will be toast, however
hope that helps,
Ryan
Old Mar 13, 2004 | 10:16 PM
SCoop's Avatar
SCoop
Ryan, I'm not so sure about that... I had an intake installed a few months back, for which the battery was disconnected for about 20 minutes. All I had to reset when finished was the clock; my radio settings were just fine.
Old Mar 13, 2004 | 10:47 PM
Ryephile's Avatar
Ryephile
I stand corrected! using flash in the radio is news to me - cool stuff.
thanks for the clarification SCoop!
W0TM8
Dec 19, 2019 07:50 AM
Aug 21, 2015 10:41 AM
PhoenixR61
Aug 21, 2015 07:40 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
xpunisherx
Aug 10, 2015 10:50 PM
