HELP needed. ABS light on after adjusting Koni rears
Old Apr 4, 2004 | 05:36 AM
ThumbsUp's Avatar
ThumbsUp
I dropped the rear coil over units yeaterday to adjust the Konis, and had inadverdently left the ignition switch on. As you may know, dropping the rear units can cause some degree of tugging on the rear ABS sensor line. Anyway, when I got it back together, the ABS, DSC, and tire pressure monitor lights are all on. I have checked to make sure I didn't unplug the sensors, and a casual observation shows everything is OK. I did have to struggle with one of the ABS lines to get it back in the clip on the shock and am fearing I may have broken the wire internally.
Any ideas? How can I clear the lights assuming everything is OK?
Old Apr 4, 2004 | 02:33 PM
mattcoon's Avatar
mattcoon
I left you a reply in the forum under Performance Modifications. Let me know if this helps. I will look for better specs tomorrow at work and give you some better details.
Old Apr 4, 2004 | 07:29 PM
Yucca Patrol's Avatar
Yucca Patrol
Greg,
Call Stephen at Stephen's garage tomorrow. He could most likely quickly reset the light and check if it is ok.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Emnotek
Aug 13, 2015 05:47 PM
OutMotoring
Aug 6, 2015 09:32 AM
