My rear end squeeks...
Old Mar 23, 2004 | 05:51 PM
dominicminicoopers's Avatar
dominicminicoopers
...not not that way
When I' goping down the road the rear end of my car squeeks. I think it might have to do with the suspension, but am not totally sure. Any ideas?
Old Mar 23, 2004 | 05:55 PM
Ryephile's Avatar
Ryephile
I was gonna say....
Speaking of lube - have you checked your sway-bar and/or control arm bushings for adequate grease quantity? Otherwise, could be your boot latch.
"Lube me up, Scotty",
Ryan
Old Mar 23, 2004 | 06:01 PM
pocketrocketowner's Avatar
pocketrocketowner
and here I thought we were dealing with a tight ***.......
Old Mar 24, 2004 | 03:56 AM
holdenontoit's Avatar
holdenontoit
either you are using too much soap, or not enough preparation H
Old Mar 24, 2004 | 05:04 AM
dandp's Avatar
dandp
Could be the boot latch issue. Wrap some black electrical tape around the metal part on the hatch. Worked for me....then the sunroof rattle started.
Old Mar 24, 2004 | 09:35 AM
DrMarkie's Avatar
DrMarkie
You didnt just pick your car up did you?
Mine squeaked badly at the start. They had forgotten to remove the shipping/packaging materials from the rear suspension.
Old Mar 24, 2004 | 09:39 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I think Dominic has had his car for about a year.
My suggestion for getting rid of the squeaky rear end is to eat fewer beans.
Old Mar 24, 2004 | 09:44 AM
zfxr's Avatar
zfxr
Man I had some Taco bell yesterday for dinner, man it was squakin up a storm... I was expecting lift-off or something... T minus 10, 9, 8, 7, 6, 5, <Go For Auto-sequence start>, 4, 3, 2, 1! We have liftoff!!!
Old Mar 24, 2004 | 12:48 PM
MrWhoa's Avatar
MrWhoa
Im sorry... I cant stop it....
What can be said about your rear end that hasnt already been said about Iraq, it's all bombed out and depleted
Ok.. seriously check the boot hatch. Mine squeekethed and I adjusted the two little black *****/boot stops and no more squeaky.
Old Mar 24, 2004 | 01:05 PM
asodestrom's Avatar
asodestrom
Beano! :evil:
Old Mar 24, 2004 | 01:12 PM
MGCMAN's Avatar
MGCMAN
Could be hemaroids. Try preparation H
Old Mar 24, 2004 | 01:14 PM
dominicminicoopers
No Go! I dripped beano all over the rear end and it still squeeks
Is there grease points in the rear suspension (e.g. Zirc fittings)?
countrym's Avatar
countrym
You're sitting on a duck.
Old Mar 24, 2004 | 08:07 PM
pocketrocketowner
Spray EVERYTHING with WD-40...NO, not your butt....it is bad for your skin.....
Old Mar 24, 2004 | 08:12 PM
seashelly's Avatar
seashelly
hmmmm.....
Squeaky rear on this thread, and limp hose on another!
Old Mar 24, 2004 | 08:44 PM
Ryephile's Avatar
Ryephile
EWWWW - definitely NOT WD-40.
Energy suspension has specific white grease for rubber and polyurethane bushings. uhh, do a Google, I'm feelin' lazy
Old Mar 25, 2004 | 06:35 AM
dominicminicoopers
Speaking of hose, my dealership gave me a stiff one and now I find out that this stiff one will go limp too in a matter of time Doesn't that just suck? See this thread for my PCV issues
Rye, I'll find some energy white grease to lube up my rear end instead of the WD-40.
_________________
Happy Motorin'
http://www.aminivacationinvegas.com/survey2.php
Old Mar 25, 2004 | 06:45 AM
Johnna's Avatar
Johnna
Seriously now - at least for a moment.
I've had hatch latch rattles and squeaks from the beginning and it's a real pain in the (r)ear. Electrical tape works but may not be the final sollution. MINI now has a new style hatch latch to remedy the situation.
Old Mar 25, 2004 | 06:50 AM
The_Beastmaster's Avatar
The_Beastmaster
Don't forget to check the loose nut behind the wheel!
Old Mar 27, 2004 | 01:39 PM
dominicminicoopers
Silicone Spray lube on each of the pivot areas for the rear suspension took care of my issue. Worked much better than Beano.
Old Apr 3, 2004 | 02:14 AM
pocketrocketowner
So does this mean you're no longer a tight ***???
Old May 13, 2004 | 08:51 AM
dominicminicoopers
Well the squeek came back a few weeks ago. My 1st inspection just came up at 33K and they were able to locate the arethat was causing the squeek!
OK, hold on to your pants... it was the linkage for the Xenon headlight autolevers!!
What? I must be crazy. The headlights are in the front of the car, right? Right?
The "sensor" for autoleveling is linked to the rear suspension so it can sense when the car squats or rises. Whod'da thunk it.
Old May 13, 2004 | 06:21 PM
pocketrocketowner
Ain't buying it......my previous theory still holds......
Old May 13, 2004 | 06:26 PM
dominicminicoopers
Which theory was that?
Old May 14, 2004 | 06:24 PM
pocketrocketowner
tight ***.......
