drive shaft removal
Old Apr 11, 2004 | 02:51 PM
Jonauto's Avatar
Jonauto
how do you seperate the driverside drive shaft from the transmission, the service manual is no help with this?
Old Apr 11, 2004 | 05:29 PM
MiniPilo's Avatar
MiniPilo
Try looking at TIS Document 3160003 and 3160004
Let me know if that helps..
Old Apr 11, 2004 | 07:57 PM
MINI-MadMan's Avatar
MINI-MadMan
Ask Jesse James. You'll probably only need one tool......a cutting torch. Sorry..couldn't resist. Hope the Cispy MINI project is coming along good.
Cheers,
Old Apr 11, 2004 | 08:23 PM
BC28's Avatar
BC28
Remove the nut in the center of front hub, detach lower ball joint, steering tie rod and sway bar end link. push the driveshat back into the transmission while pulling the front hub towards you until the tip of the drivehaft clears the front hub. Then pull the driveshaft out.
Old Apr 12, 2004 | 11:51 AM
Jonauto's Avatar
Jonauto
could you clearify some drive shaft lingo for me, whats the front hub?
Old Apr 12, 2004 | 12:01 PM
BC28's Avatar
BC28
The front hub is where your wheel bearing, driveshaft and brake rotor attach to.
The nut that you need to remove is in the center as you face the brake rotor. The nut has a goldish color to it. You need to remove this nut to free the driveshaft.
Old Apr 12, 2004 | 12:05 PM
Jonauto's Avatar
Jonauto
ive done all that up to removing the drive shaft from the tranny.... so all i need to do is push the drive shaft into the tranny as i pull the hub off?
Old Apr 12, 2004 | 12:23 PM
BC28's Avatar
BC28
yes, but you may need a helping hand to pull and swing the front hub away while you push the driveshaft into the transmission with one hand and move the drive shaft tip so it will clear the front hub.
Old Apr 12, 2004 | 01:32 PM
Super_MINI's Avatar
Super_MINI
Can the driveshaft be pulled out of the Transmission with the driveshaft still connected to the hub?
Old Apr 12, 2004 | 01:43 PM
BC28's Avatar
BC28
yeah, but you would also have to disconnect the spring/strut and remove the brake caliper or brake line.
Old Apr 12, 2004 | 01:53 PM
Jonauto's Avatar
Jonauto
ive done all that but the drive shaft doesnt want to come out, is it just suposed to slide out or does it need some serious encouragement?
Old Apr 12, 2004 | 02:02 PM
BC28's Avatar
BC28
My passenger side one slid out easliy but I needed to "encourage" the drivers side out.
Old Apr 24, 2004 | 12:18 PM
Jonauto's Avatar
Jonauto
i still cant get this friggin thing out, its stuck.... any ideas?
Old Jul 21, 2010 | 06:02 AM
FlipSmini's Avatar
FlipSmini
put your purse down
Melvinyip
Apr 17, 2020 09:28 AM
alistaircookie
Oct 8, 2015 10:52 AM
Zettinger
Aug 25, 2015 04:04 PM
flredmini
Aug 12, 2015 06:35 PM
ludedude
Aug 10, 2015 07:16 PM
