PDA
View Full Version : Electrical
Pages : 1 2 3 [4] 5 6
  1. Electrical Swap HID's between cars??
  2. Electrical ScanGauge Oil Pressure
  3. Electrical NEED HELP: extra LED license plate light install
  4. Electrical Opinions on JCW Shift Indicator?
  5. Electrical Is it possible to program the radio to default to this? *PIC*
  6. Electrical R57/R58 internal light
  7. Electrical Installing Marshall Boost Gauge in 2008 MSC
  8. Electrical Heated seats module/wiring
  9. Electrical OEM Driving Lamps clouded up
  10. Electrical Possible Solution to Remote Start with C/Access?
  11. Electrical Better Halagons ??
  12. Electrical How To: Disable Xenon DRL and Enable Upper Fog DRL
  13. Electrical EWS Alignment
  14. Electrical can someone with schematics tell me what the d2 pin on dme is for?
  15. Electrical Setting NCSEXPERT for MINI alarm
  16. Electrical NCSEXPERT Best Error
  17. Electrical DME replacement with used
  18. Electrical TPMS Differences, US and Europe
  19. Electrical Any diagnostic cables available for short-term loans or leases in the US?
  20. Electrical Will it throw a code if radio/speedo/climate unconnected??
  21. Electrical LCI or Countryman system changes?
  22. Electrical Can you access the ULF module with NCS?
  23. Electrical Headlight question
  24. Electrical bulb out eliminators
  25. Electrical Wiring Color Code at Reverse Lamp of 2011 MCS?
  26. Electrical Accessport
  27. Electrical Angel Eyes that replace your running lights
  28. Electrical Headlight Harness Help
  29. Electrical Tra mode
  30. Electrical Heater controls & switches don't work
  31. Electrical Aftermarket headlights?
  32. Electrical programming new key
  33. Electrical Pinch Sensor Re-Calibration Programming
  34. Electrical Additional LED Brake Lights
  35. Electrical LED Parking Lights Throwing Error, Any idea of what OHM/Watts resistor needed?
  36. Electrical Trouble Sourcing A NCSExpert Cable
  37. Electrical Want to confirm correct bulb for R56 JCW 09 DDM HID Kit
  38. Electrical DIS for mini R56
  39. Electrical Retrofit DTC/EDLC is it just programming?
  40. Electrical OEM HID Xenon Retrofit
  41. Electrical Switched power in map light cover area not working? Purple/Gray isn't working in JCW
  42. Electrical Where are you placing your amps? Thinking of under driver/passenger seat
  43. Electrical Secondary footwell lighting + switched 12V source!
  44. Electrical Modifying 2011 R56 VO
  45. Electrical Modifying 2011 R56 VO
  46. Electrical Radar wiring help, Read How To but Purple wire isn't working
  47. Electrical another ddm hid kit problem :(
  48. Electrical Xenon Retrofit w/ NCSExpert
  49. Electrical Problem with Auto Start Stop
  50. Electrical Replacing halogen headlights for factory HID on 2011 R56 cooper S
  51. Electrical Part Search: Rear Third Brake Light Connector
  52. Electrical tweaking harman/kardon sound
  53. Electrical coding folding mirrors
  54. Electrical Adding 12v for USB Port Drivers Side
  55. Electrical Problem coding FRM/FRM2
  56. Electrical joey mod melting the inside of the light housing! any help?
  57. Electrical Question for Prosport Boost Gauge Owners
  58. Electrical Anyone running NCS in So FLA?
  59. Electrical Gauge wire size to tap in to gauges?
  60. Electrical What are my options for retrofitting black housing HID's?
  61. Electrical grounding help
  62. Electrical Adding a second Horn via flips Switch?
  63. Electrical R56 front clear signal replica?
  64. Electrical Needing help changing lights for r56
  65. Electrical LED License Plate Lights...
  66. Electrical Cigarette lighter socket not working, fuse ok..
  67. Electrical Change VIN FRM SPEG
  68. Electrical OEM Aux-in has 4 wires?
  69. Electrical Best Source for: 12v, ground, and ACC
  70. Electrical Resetting air bag light after aftermarket seat install
  71. Electrical To those with their Radar Detector hard wired in the above head console
  72. Electrical Gauge Wiring
  73. Electrical Batteries for R56
  74. Electrical Radio Button Not Working
  75. Electrical Silver to Black Xenon - good deal?
  76. Electrical install OEM xenon
  77. Electrical Adding Boot Lamp
  78. Electrical Horn toot when locking/unlocking
  79. Electrical Major computer freak-out
  80. Electrical No sound from speakers. HELP
  81. Electrical Installing MFSW and Cruise
  82. Electrical Hypothetical HID Retrofit
  83. Electrical Show version of ECU software load
  84. Electrical Lamp wiring question
  85. Electrical installing the iPod connect option
  86. Electrical Faulty BEST version when reading FRM module for 2011 R56
  87. Electrical Retrofit Comfort Access?
  88. Electrical More on the Xenon headlamps
  89. Electrical Need help with Driving light install!
  90. Electrical Help, motive failure
  91. Electrical Can I add an aftermarket toggle switch in my bank for PIAA driving lights?
  92. Electrical Removal of main line at speg fuse box
  93. Electrical Hid Kits
  94. Electrical Torque app for Android compatibility and settings
  95. Electrical IPOD adapter for my 2007 with the HK stereo
  96. Electrical Need help with Pulsar 3rd brake light flasher
  97. Electrical Gauge light wire
  98. Electrical ECU Location?
  99. Electrical Battery replacement - Interstate compatibility??
  100. Electrical battery relocation
  101. Electrical I need help with DDM HID kits!!
  102. Electrical The [Complete] NCS Expert DIY
  103. Electrical Swap out driving lights?
  104. Electrical Which fuse for turn signals
  105. Electrical Vent Pod
  106. Electrical Coding in the Sport Button, turning off CDN DRL and other NCS Expert stuff
  107. Electrical You've Got To Do This!!!!!!!
  108. Electrical need some help with y cables & Ipod !
  109. Electrical Flucuating oil press gage
  110. Electrical Rear Lights 2011 Clubman retrofit
  111. Electrical Removing R56 xenon headlights?
  112. Electrical Ultra-Gauge. Who's got one?
  113. Electrical Factory Alarm in a 2011
  114. Electrical NCS Expert Directory
  115. Electrical Battery Terminal Problem
  116. Electrical NCSExpert for my '11 Cabrio S
  117. Electrical I'm installing a Blinder M-27 Laser Jammer today.
  118. Electrical Making the alarm light blink?
  119. Electrical Aftermarket LED Tails
  120. Electrical fog light install with hids
  121. Electrical 2011 R55 - Xenon High Beam Wire
  122. Electrical NCSExpert DIY(do it yourself)
  123. Electrical NCSExpert for beginners
  124. Electrical Radar Detector Hardwire - Which fuse
  125. Electrical Anyone have a wiring schematic?
  126. Electrical OEM driving lights fuse
  127. Electrical LEDs in scuttles...
  128. Electrical Mach V LED DRL install?
  129. Electrical Xenon to Halogen
  130. Electrical D-Can cable software file error
  131. Electrical 3rd Brake Light Dead?
  132. Electrical QI45 remote radar detector install
  133. Electrical Tail lights mod for Gen 2?
  134. Electrical Headlight swap possible???
  135. Electrical Blinglights
  136. Electrical LED projectors?
  137. Electrical 80w h13 bulbs
  138. Electrical Can't find the "how to" for removing sunroof control panel
  139. Electrical SprintBooster Installed/Check Engin Light won't go off.
  140. Electrical xenon upgrade?
  141. Electrical 2009 R57 Trailer Wiring
  142. Electrical 2 pc white LED Audi style accent lights...on Mini
  143. Electrical Making rear 12v accessory plug Hot (2009 R57)
  144. Electrical Brake Light Wiring Help
  145. Electrical Can you cut off the electronic nannies?
  146. Electrical Anyone moved rev counter closer to steering wheel?
  147. Electrical Has anyone tried this HID kit?
  148. Electrical Interior LED's
  149. Electrical Retrofit rain sensor?
  150. Electrical PIAA H13 XtremeWhite Plus
  151. Electrical Has anybody installed the horn from Moss Mini?
  152. Electrical Mini Cooper alpine 65.12-6 961 275 stereo
  153. Electrical $470 + tax for Driving Light install...
  154. Electrical Constant ticking sound from HID harness relay
  155. Electrical PLEASE HELP!!!!!!!!!!!!!!!! lol!!!
  156. Electrical Driving lamp kit question...
  157. Electrical Anyone used MiniMania driving light brackets?
  158. Electrical Mini OEM driving light kit OR Hella Black Magic 500 kit??
  159. Electrical HID Install Problem (Flicker on start)
  160. Electrical Rear Fog Light Retrofit on 2011
  161. Electrical 2011 Clubman tail lights on 2008?
  162. Electrical Possible to 'convert' an HID kit?
  163. Electrical Some LED's
  164. Electrical Need a quick boost install diagram.
  165. Electrical Remove cig lighter socket?
  166. Electrical Quick fog light question
  167. Electrical Disable TPMS
  168. Electrical Factory driving light question...
  169. Electrical Always show digital speed modification
  170. Electrical SW programming for rear fog lights
  171. Electrical DEL rear lights "2011" in "2010"?
  172. Electrical OEM Dome light assembly
  173. Electrical My Valentine One Concealed Display Multi-Color LED Mod
  174. Electrical speaker subs
  175. Electrical Close Windows & Sunroof with the remote, yes you can
  176. Electrical looking for ignition wiring
  177. Electrical Gauge install
  178. Electrical My 2010 R56 with Retrofitted Bi-Xenon custom headlights
  179. Electrical Wire Color Codes
  180. Electrical My Xenon Headlights
  181. Electrical How do I add an addition lighter socket?
  182. Electrical Headlight won't turn off after trying replacement bulb!
  183. Electrical One touch sunroof module on 2010 cooper
  184. Electrical Light switch wire
  185. Electrical Help-replaced halogens w/OEM Xenons and they dont work
  186. Electrical Replace OEM MINI driving lighs with aftermarket?
  187. Electrical Cable holder alternatives?
  188. Electrical OBD gauge choices
  189. Electrical Problems hooking LED's up to front speakers
  190. Electrical Radio display fading in heat
  191. Electrical Windshield Washer's not working
  192. Electrical dash lighting for after market gauges
  193. Electrical Adding Heated Washer Jets
  194. Electrical Sprint Booster Power Converter
  195. Electrical MCS Battery
  196. Electrical White Fog Lamp Bulbs
  197. Electrical PLX DM-100/200 OBD2 Gauge
  198. Electrical New Engine Wiring Harness - Now Serial Link Failure
  199. Electrical Driving Lights electrical problem HELP!!!
  200. Electrical trying to hook up boost gauge need help
  201. Electrical Access to tailights on R57
  202. Electrical Schematic for gas gauge
  203. Electrical remote start + app?
  204. Electrical Questions about installing Hella lights
  205. Electrical HID conversion ... please help
  206. Electrical 55W HID For Lights
  207. Electrical need quick help re: aux light wiring
  208. Electrical Auto on fogs?
  209. Electrical shift light/rpm gauge hook up help??
  210. Electrical Time To Replace BCM ? (BC1)
  211. Electrical Do I need this adjust element for fog light?
  212. Electrical H11 LED light bulb on R53
  213. Electrical HID bypass needed for 35W HID H11 to work?
  214. Electrical PIAA Driving lights installation on 2010 JCW
  215. Electrical 45mm gauges
  216. Electrical Do Hella Optilux with angel eyes fit in the front fog location?
  217. Electrical HID Fog lights
  218. Electrical Override Factory Driving Lamps Outside of High Beams
  219. Electrical AutoMeter shift light?
  220. Electrical LED Sidemarkers?
  221. Electrical ipod interface
  222. Electrical Rear fog lites as brake lites?
  223. Electrical Driving Light Vibration
  224. Electrical ralley lights CEL question
  225. Electrical 2010 Driving Light Install
  226. Electrical Installed Scan Gauge2
  227. Electrical Radio won't turn on and fuses are all good....
  228. Electrical Possible to replace Speedometer/Instrument Panel with factory Navigation/Custer?
  229. Electrical Need help with ground for V1 hardwiring!!
  230. Electrical Blade or Mini Blade?
  231. Electrical Possible speedo solution
  232. Electrical Hella FF200 driving light install questions
  233. Electrical Sport button mod--how's it work?
  234. Electrical Is my HID fog light DIY project doable?
  235. Electrical Help Changing '06 Running light!
  236. Electrical Hooking up my FF200's to my new 2010
  237. Electrical Key Fob - is it RFID?
  238. Electrical Has anyone tried this foglight kit?
  239. Electrical How to read the wiring diagram....%%%
  240. Electrical Rookie gauge question
  241. Electrical V-1 is killing my dash!
  242. Electrical Fog light DIY on R55 or R56?
  243. Electrical Universal ScanGaugeII XGuage Thread
  244. Electrical HID conversion kit install help please!
  245. Electrical Flash 2 Pass
  246. Electrical Auto open sunroof
  247. Electrical buttons that dont do any thing...
  248. Electrical Escort 8500 and Garmin Nuvi 580 hardwired in my R56
  249. Electrical Parrot MIi9000 install
  250. Electrical Website for obtaining TIS documents and wiring diagrams
