Electrical Disable TPMS
Old Nov 18, 2010 | 07:24 PM
Kenneth Roehl's Avatar
Kenneth Roehl
Disable TPMS
Has anyone disabled the TPMS when installing non sensor equipped rims?
Old Nov 19, 2010 | 08:29 AM
schatzy62's Avatar
schatzy62
This can probably be done thru a software change or programing, But unfortunately not thru an easy user interface.
strobyprobey has the equipment to make these changes and is in process of going thru a lot of different modules to see what can and can not be done.
The other problem is that the dealers (even if it is changeable) will not do it because the currect US law requires that TPMS be ON all cars form model year 2008 and higher. So they will not adjust software that will break the law.
Example is the seat belt gong can be turned off but under US law it is requried so dealers will NOT turn it off for liability reasons.
Old Nov 19, 2010 | 08:37 AM
Richieb0y28's Avatar
Richieb0y28
how can i disable the seat belt gong? any easy fix? I know for my friends STI, he was able to click and unclick consistently for 30 seconds and it disabled his driver seat. Anything we can do for the MINI?
Old Nov 19, 2010 | 08:42 AM
DneprDave's Avatar
DneprDave
I read where someone here just put all four TPMS sensors in his donut spare in the trunk. The car doesn't know any difference.
Dave
Old Nov 20, 2010 | 07:37 AM
bluefox280's Avatar
bluefox280
Bravian Tech's diagnostic / convience setting interface DOES NOT allow tire pressure monitoring system deactivation at this time of writing.
- Erik
Old Nov 22, 2010 | 10:32 AM
strobeyprobey's Avatar
strobeyprobey
I am sure the tools I have can disable the TPMS or change it to the wheel diameter system. I haven't really looked much into that option. As long as the TPMS module is coded out of the car, or at the very least the Check Control warning message coded out, I am sure it can be done since TPMS is not required in the rest of the world. It wouldn't be very easy.
Old Nov 22, 2010 | 10:34 AM
schatzy62's Avatar
schatzy62
- Erik
That system may not work but the one strobyprobey is working with may very well as he seems to be able to change any and all other systems that the Bravian can not do. And I suspect it is one that will need to be set to off for some other countries that do not require it.
Old Nov 22, 2010 | 10:42 AM
bluefox280's Avatar
bluefox280
That system may not work but the one strobyprobey is working with...
Stroby, what system do you have?
- Erik
Old Nov 22, 2010 | 10:53 AM
strobeyprobey
Look in the next thread with closing the sunroof and windows with the FOB.
It is DCAN cable from ebay, and I use NCS Expert to do the coding. I am still learning myself, there is a lot to it and the German abbreviations don't help at all!
Old Dec 13, 2010 | 06:15 PM
strobeyprobey
So if you want to remove the TPMS system from the car, the Vehicle order can be updated removing the option $2VB Direct_RDC //Reifen Druck Control (fuer US-Fahrzeuge) in NCS Expert. You would have to re-initialize a couple of the modules but that should not hinder the removal. Also removing $845 from the VO should get rid of the seat belt reminder chime as well.
Old Dec 13, 2010 | 08:07 PM
Derepente's Avatar
Derepente
You are a wizard! That is wicked cool how you have been able to make those changes.
Have you ever experienced reversion or do the changes stay once you set them? Any glitches using NCS expert?
Old Dec 13, 2010 | 08:11 PM
strobeyprobey
I haven't tried removing it myself, but I am pretty sure it would work. The VO change is permanent (in non-volitile memory, stored in two modules for redundancy). The changes made to modules direclty with trace files will be cleared if the module is reprogrammed.
Old Jul 18, 2016 | 12:20 AM
ultrakill's Avatar
ultrakill
Reviving this dead thread, did this end up working to disable TPMS? Any other side effects? Thinking about going this route, I'm a software engineer by trade so I think I would know better than to tinker with an unknown code system, but I'm very intrigued.
Doc Pain
Mar 10, 2021 04:50 AM
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
ericf1993
Sep 26, 2015 03:58 PM
renchjeep
Sep 6, 2015 01:54 PM
