Electrical NCSEXPERT Best Error
Old Nov 12, 2011 | 05:04 PM
Papote's Avatar
Papote
I have followed the directions from NCSEXPERT for beginners thread https://www.northamericanmotoring.co...beginners.html
I have been able to successfully enable Comfort closing (KOMFORTSCHLIESSUNG_FB) and have the digital speed always on (DIG_SPEED_PERMANENT). I am trying to enable the blinking alarm light but have unsuccessful. I could add the value in KOMBI but not in SPEG. Every time I try to read the SPEG ECU, I get the infamous BEST error.
https://i.imgur.com/4Z0LC.jpg
Later on I plan on buying the MINI alarm. What other values must be set so it can function correctly after installed?
I have a 2008 Mini Cooper S R56
Old Nov 13, 2011 | 06:47 AM
strobeyprobey's Avatar
strobeyprobey
Upgrade your EBIASAS (sp) to 7.2 and your daten files to v41. I couldn't access the speg module until i did this.
And I just made this exact mod this week! Works great.
Old Nov 13, 2011 | 09:25 AM
Papote's Avatar
Papote
Great! Got it! I can even access the FRM module without problems.
For anyone who needs it, I found the latest BMW Standard Tools 2.10 with the EDIABAS 7.2 here.
I uninstalled the original version I had, installed the new one and then copied over the PFL (profile) file, the new V41 Datens I found on a torrent, just like the original instructions.
No problems!
Thanks.
Old Nov 13, 2011 | 05:08 PM
Papote's Avatar
Papote
Found the new BMW Standard Tools 2.10 with EDIABAS 7.2 here
http://forums.bimmerforums.com/forum....php?t=1665384
Uninstalled the older BMW Standard tools first installed the new version and followed the same instructions from the original PDF but using Datens V41 I found from a torrent.
Got it working!
Thanks!
Old Apr 20, 2012 | 08:44 AM
z3bum's Avatar
z3bum
In general BEST errors with NCSExpert are related to the versions of files you have vs. the versions of the ECUs in the car. MINIs built after summer of 2010 probably should be using v45 files. But the version files are backward compatible, so you should always update.
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
11
Sep 30, 2015 02:11 PM
dutchhome
Sep 30, 2015 07:17 AM
ericf1993
Sep 26, 2015 03:58 PM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
