Electrical Light switch wire
Old Sep 24, 2010 | 11:50 AM
Bigprfed22's Avatar
Bigprfed22
Light switch wire
I havent been able to find a wiring diagram for the r56.
That being said....
I have my gauges installed but at night i like to run my gauges dim, the problem with that is that the actual tap im using for the prosport needs a full 12v to switch to red. when dim the cars lighting receives 6v. any one have any idea where i can find a full 12v light switch wire that does not decrease with the dimmer?
Old Sep 24, 2010 | 01:14 PM
Bigprfed22's Avatar
Bigprfed22
dont all speak at once!
Old Sep 26, 2010 | 11:00 AM
Minidrivr's Avatar
Minidrivr
According to Alta's instructions for wiring up their gauges, they use a wire going to the DSC module.
http://www.altaperformance.com/share...ampinr210w.pdf
I haven't confirmed though and don't know if the 2010 might be different. Check that out with a tester and let us know.
Old Sep 26, 2010 | 11:35 AM
Bigprfed22's Avatar
Bigprfed22
thats what i have it hooked to right now, but if you dim your lights the voltage goes from 12 to 6v, i need a light switched wire that stays at 12v regardless of dimming
Old Sep 26, 2010 | 12:51 PM
rkw's Avatar
rkw
If it's acceptable to you, there are fuses that are switched on with the ignition: https://www.northamericanmotoring.co...not-fuses.html
For a wire switched on with the lights, look through the wiring diagrams: http://www.bmw-planet.com/diagrams/release/en/index.htm
You can connect to the tail light, but there might be a more convenient connector further up front where its signal comes from.
Old Oct 20, 2010 | 07:02 AM
Bigprfed22's Avatar
Bigprfed22
Thats what i was connected to , i switched to a stri gauge as the prosport was junk... The dim feature has the same problem though. gonna search for one this weekend. i hate having my gauges bright.
Old Oct 20, 2010 | 07:59 AM
strobeyprobey's Avatar
strobeyprobey
Here is the wiring diagram for the '07. Should be very similar to your car.
http://www.mcaw.info/wds/mini/us/r56/index.htm
That being said, anything in the interior of the car will have the voltage you found, the easiest thing I can think of for your 12V source for dimming would be to tap off the front parking/city light power wire.
Old Oct 20, 2010 | 08:08 AM
Bigprfed22's Avatar
Bigprfed22
I get an error on the web based system when i click on the parking light link, can you screen shot it?
Old Oct 20, 2010 | 09:11 AM
thirdraildesignlab's Avatar
thirdraildesignlab
you arent alone. I tried to look for you but I'm seeing XML errors on several of the diagrams...
Old Oct 20, 2010 | 09:18 AM
Bigprfed22's Avatar
Bigprfed22
Old Oct 20, 2010 | 10:39 AM
strobeyprobey
I can't take a screen shot as the diagram is too wide for one window.
Click here,
http://www.mcaw.info/wds/mini/us/index.htm
then click Tech Requirements at the bottom right, then click Start System Test.
Make sure you have the following:
You need to use Internet Explorer (32-bit), Java version 1.4.1 or higher, scripting of Java Applets enabled
And the big thing you are probably missing:
Adobe® SVG Plugin 3.0 or higher installed
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
PSIChocolate
Aug 13, 2015 12:46 PM
