Electrical LED Parking Lights Throwing Error, Any idea of what OHM/Watts resistor needed?
I just installed some parking lights today and I am receiving a CC-ID 131/132 Error which is for the left/right parking light.
I tried doing a 1/2 Watt 220 OHM resistor I had sitting around and the warning light still came up.
Anyone fixed this before with a proper resistor? It is kinda annoying to have the Light Code pop up.
Thanks :D
Thanks :D
I used a higher wattage bulb and have not had any problems. I have replaced
every bulb except the front ones, but it was expensive. www.v-leds.com
is where I got them. If you get several you can ask for a discount also if you join their facebook page likewise.
I haven't had to use these on my MCS yet because I am currently only using LEDs for my interior lights and rear fog light / brake light conversion (LEDs in fog position only) I did have an issue on my '36 Chevy Coupe since all the interior & exterior lights on the car (except headlights) are LED. To get my turn signal to work I installed these load resistors to make the turn signals flash properly.
http://www.ebay.com/itm/2X-6ohm-50W-...ht_3717wt_1270
Work great and they are cheap.
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
