View Full Version : Electrical
- Electrical Cruise control default to "on "?
- Electrical HID retrofit Kit
- Electrical R57 Auto Climate Control Upgrade
- Electrical Let see your lights
- Electrical Does it make sense to use OEM wiring w/aftermarket lights
- Electrical Anyone using rectangular Driving Lights
- Electrical Source for knee protection panel with driving light switch cutout?
- Electrical my first mod!!
- Electrical Maggie has a new trick!!
- Electrical LED Rear Foglights
- Electrical Power for device
- Electrical Always-On Fog Lights?
- Electrical Backing/Reversing lights - MCS 2007
- Electrical Source for power to driving lights?
- Electrical clubman alternator swap
- Electrical AutoMeter water temp gauge (elec) HELP!
- Electrical 2009 Footwell Module pinouts
- Electrical Shark Fin Anyone?
- Electrical Installtion for Autometer Boost Gauge ?
- Electrical Recommendations for driving lights smaller than the Hella 500s
- Electrical Garage Door Opener Mod?
- Electrical DEFI BOOST GAUGE INSTALLATION ANYONE ?
- Electrical need help with boost guage install
- Electrical Aftermarket 2 Way alarms?
- Electrical Mount driving lights directly to a JCW grill without using the oem style brackets?
- Electrical OBD II Gauge Option
- Electrical Anyone ever try LED turn signals?
- Electrical Window not going all the way up...
- Electrical MFSW Retrofit
- Electrical Changing a fog lamp bulb
- Electrical Fog/Driving Light Options
- Electrical Reverse Tilt Mirror Module R56
- Electrical Are these the couplings for my rear fog lamps? (photo reference)
- Electrical Xtreme Bi-Xenon HID H13/2008 Kit in 08 Cooper questions.
- Electrical 08 Mini Cooper S R56 OEM Driving Light install
- Electrical EML
- Electrical 2010 MCS and the Autosport module.
- Electrical AutoSport and 2010 question.
- Electrical Rear fogs used as add'l tailights?
- Electrical Cool grill mod idea, can it be done?/how?
- Electrical Boost Gauge Wiring R56
- Electrical UNICHIP DESTROYED MY ECU
- Electrical R56 ALARM SIMULATOR KIT
- Electrical Sport Button Modification Comparo
- Electrical Who has H13 HID KIT Installed?
- Electrical I ditched my parking lights
- Electrical do all fuses go off during crank??
- Electrical Always-hot 12v outlet?
- Electrical How do I install the battery??
- Electrical Wire Rear Fogs / Retrofit
- Electrical Front fog lamp bulbs
- Electrical CarPC wiring
- Electrical Best mod I have added to my car
- Electrical programmable flasher/brake lights
- Electrical KP Tech window/sunroof module 2009
- Electrical I want my OEM Driving Light on WHEN..
- Electrical Odometer
- Electrical Doing the "add rear fogs into the brake light mod"
- Electrical any elect techies out there help me figure out this idea
- Electrical splicing into switchboard for driving lights
- Electrical R56 Alarm Modification
- Electrical Higher Amp Driving Lights on EOM Kit?
- Electrical Innovate Mortorsport Gauges Kit
- Electrical Replacing reading lights??
- Electrical where to get ELM 327 for pc interface
- Electrical DIY Valentine 1 above mirror mount
- Electrical Matching interior neon
- Electrical OEM Driving Light Wires
- Electrical Retrofitting Airbag deactivation switch
- Electrical need help wiring up my DEFI gauges.
- Electrical Modules
- Electrical Craven Speed Tapless Oil pressure/temp
- Electrical OEM Driving light wiring question
- Electrical Sport Button and DSC on switch
- Electrical Easy accessory control...
- Electrical Driving light Installation Problem
- Electrical Where to locate Supertones?
- Electrical delete
- Electrical fog lights or marker lights?
- Electrical Installed a Boost Guage Using Add a Circuit
- Electrical Driving Lights install
- Electrical aftermarket amp
- Electrical Lighter Socket Replacement
- Electrical Bi-xenon HID kit Problem. Anyone?
- Electrical Help!! Please :)
- Electrical HELP! hot (to the touch) fuse in fuse box???
- Electrical DRLs obtained, finally
- Electrical heelp :( weird problem!
- Electrical Inexpensive alarm
- Electrical V1 Hardwire - Cabrio
- Electrical Where are the Mini "tones" stored?
- Electrical 2009 NAV video integration
- Electrical 02 Sensor
- Electrical Type of wire to use
- Electrical Help! Airbag light on after changing wheels
- Electrical Has anyone installed these?
- Electrical Cincinnati Microwave Shifter ZR4 Installation
- Electrical Rally lights - replacement glass lens
- Electrical Quick chip question...
- Electrical Retrofit Voice Control - Possible?
- Electrical Replacement Antenna
- Electrical Noisy turn indicators R56
- Electrical Oil Temp/Press Gauge Sender Locations?
- Electrical LEDs color change on cluster?
- Electrical Auto Folding Mirror MOD Request
- Electrical Weird plug?
- Electrical Retrofiting lighting package?
- Electrical Rear fog light
- Electrical Rear Fog Light Fuse?
- Electrical Retrofit smart phone prep?
- Electrical Installed Alta boost gauge - BIG problem
- Electrical data logging tool
- Electrical Looking for a MINI Tech here on NAM
- Electrical Please help me to do this...
- Electrical NEED AIRBAG HELP!!!
- Electrical OBDC gauges but analog display ?
- Electrical Rear Fog Ohm Rating?
- Electrical Bulb Out Warning
- Electrical What would happen if the bulb-out warnings keeping on...
- Electrical R56 Retrofit OEM Bi-Xenon
- Electrical Unichip experiences - Any positive ones?
- Electrical Tapping the sport button?
- Electrical Annoying Openometer
- Electrical Radar detector/GPS hiding wires
- Electrical Missing sun roof toggle
- Electrical Removing side markers?
- Electrical Trailer wiring help needed!!!
- Electrical Clear rear fog lights
- Electrical Custom Installed Stealth Passport 9500 ci detector
- Electrical The Easiest and Best Connector Ever!
- Electrical Lights or no lights? Smoke or no smoke? Helpppp!
- Electrical Retrofit MFSW cruise + radio controls R56 R55 R57
- Electrical Need help from the electronics experts
- Electrical Boost gauge
- Electrical Low beam height adjustment '09?
- Electrical Passport 9500ci - install locations
- Electrical DSC, cruise, wipers, OBC disabled... HELP!!!
- Electrical OEM driving (auxiliary/rally) lights wiring and cu
- Electrical Go into limp mode/rev limit on purpose?
- Electrical Ready to attempt rear fog light toggle switch install
- Electrical Cigarette lighter turned into something useful
- Electrical What sensor/speaker is in the top light housing?
- Electrical Low Speed Auto Door Locks
- Electrical Auto open sunroof?
- Electrical Wiring aftermarket rear fogs into brake lights
- Electrical ECU upgrades for 2009 Clubman?
- Electrical Gauge Questions
- Electrical Aftermarket Aux Lights Wiring - Need Help!
- Electrical Hella 500 Wiring
- Electrical Replace R56 Non-HiFi (Boost) Speakers, NO AMP?
- Electrical New Boost Gauge in the R56
- Electrical KBus Tap without dissassembly
- Electrical Hardwire GPS with auto on Sport button mod using fuse 32
- Electrical Light Setup
- Electrical Front parking lights
- Electrical CANBUS and MOSTBus Interfacing for CarPC
- Electrical Auto-on Sport Button kit
- Electrical Lighting annoyances
- Electrical Splicing the cig lighter?
- Electrical My new Hella driving lights rock my world
- Electrical Right headlamp, where???
- Electrical ScanGauge II Antics
- Electrical R56 Aftermarket Audio Mods (Please Share!)
- Electrical Replacing R56 Driving Light Bulbs
- Electrical JCW / Mini Accessory for Temp / Electrical Gauges
- Electrical Changing seat belt noise volume?
- Electrical Vanity Mirror Lights
- Electrical iPhone 3G cradle
- Electrical Convert Stock Rally lights to turn on with Low beams
- Electrical Can you silence the GONG????
- Electrical Switched power under Bonnet
- Electrical Driving lights switching on with xenon high beams
- Electrical R56 Driving Light Bulb Type
- Electrical Quick and Dirty Garmin Nuvi Install
- Electrical Retrofitting the factory self dimming rearview mirror + Homelink
- Electrical Retrofit missing Clubman fog lamps
- Electrical Wait, radar detector fries fuse panel?
- Electrical "Mood" lighting and instrument panel dimmer
- Electrical Wiring harness from hatch ??
- Electrical EE/Electrical Gurus Help! LED Resistor Ques.
- Electrical Hi-Lo HID aftermarket install problem
- Electrical LED wiring
- Electrical W5W L.E.D. replacements
- Electrical Seat belt reminder?
- Electrical Electrical Gurus: Mood Lights & Dome Light
- Electrical Airbag warnning light.....
- Electrical Fog light HID kits?
- Electrical Anybody know of a clutch-less engine start hack/mod?
- Electrical New iPod/iPhone adapter solution ??
- Electrical Electrical Diagram site!
- Electrical Newest L.E.D. fog lamps in bright white
- Electrical Fog Lights always on
- Electrical How can I use rear fog switch for extra front driving lights?
- Electrical Slim HID from ebay on a 02MCS, <$100
- Electrical Light bulb numbers
- Electrical Fuse & Wiring Issue - Gen II R56
- Electrical Trailer lights wiring?
- Electrical Programming Using J2534 interface
- Electrical led dome light installed(blue)
- Electrical LEDayLine daytime running lights
- Electrical blaster coils
- Electrical Using add a fuse to get on/off with key
- Electrical Which fuse tp use my add a fuse with for radar
- Electrical Has anyone used an OEM "sport" style button in the blank?
- Electrical DashDyno drawing down battery when car is off
- Electrical SIRIUS PNP install questions
- Electrical Gauge Pod
- Electrical Keeping Aux light button on all the time?
- Electrical What fuse should I tap in an R56?
- Electrical PLX DM-200 happy with it?
- Electrical Connecting Amp to Battery
- Electrical ScanGauge Settings, what do you watch?
- Electrical DIY Fog light install (in-bumper)
- Electrical Pics needed for wiring through the firewall
- Electrical R56 with R50 driving light harness?
- Electrical AC/Vent Fan
- Electrical Adding a 12V plug in center armrest?
- Electrical Anyone have an oil temp guage in their R56?
- Electrical DSC+ABS+handbrake light(red) all light up at the same time
- Electrical squeaky factory gauges
- Electrical Radar detector in the antenna Base (Valentine)
- Electrical Sport Button Activation
- Electrical Need Tutorial (DIY) for Fog Lights
- Electrical Rally Lights - help!
- Electrical Resetting the Service light
- Electrical Help! In middle of V1 install, can't locate ground!
- Electrical light models
- Electrical 07 auto up windows
- Electrical Sub Woofer and Amp Install Question
- Electrical HID Conversion Kit for Fogs and/or OEM Driving Lights?
- Electrical What are these Fuses for?
- Electrical Any consensus on stubby antenna vendor?
- Electrical Alta gauges lighting problem
- Electrical No power outlet in the boot????
- Electrical Anyone Ran Laser jammer Descretely?
- Electrical Sun Roof Auto open/close
- Electrical V1 Hardwire - Need Some Help
- Electrical My new back-up camera
- Electrical Removing driver side visor/vanity mirror
- Electrical Bluetooth Pairing in the MINI?
- Electrical Question about gauges!!
- Electrical problem with ALTA Boost gauge
- Electrical My new security/dashcam/DVR set-up
- Electrical installing alarm in SF bay area
- Electrical Battery Charger During Storage
- Electrical Want to upgrade the sound systems...need some suggestions
- Electrical Does this light bar fit?
- Electrical AWESOME
- Electrical extra cigarette lighter type outlet
