Electrical ScanGauge Settings, what do you watch?
Old Aug 4, 2008 | 05:03 PM
hopper's Avatar
hopper
I just installed a Scangauge and am wondering what people find valuable as a default set of parameters. I currently have Intake Air Temp, Water Temp, Closed/open loop and Manifold Pressure. I'm not sure if the MAP and Closed/Open loop readouts really give me any valuable information, especially with an Alta PnP sitting on top of the ECU.
So veterans, how do you use your ScanGauges to maximum advantage?
Tia!
Old Aug 4, 2008 | 05:19 PM
MINIAC's Avatar
MINIAC
I have Intake Air Temp, Water Temp, Battery Voltage and Boost (XGauge) displayed, but sometimes cycle through the latter display to view other things.
Old Aug 4, 2008 | 05:29 PM
Minidrivr's Avatar
Minidrivr
I have water temp, air intake temp, voltage, and mpg.
Old Aug 4, 2008 | 05:34 PM
Tu13es's Avatar
Tu13es
MPG, FWT, RPM, MPH. Sometimes if I'm feeling guilty I'll hide the MPG.
Old Aug 5, 2008 | 02:38 AM
Berthil's Avatar
Berthil
Intake Air Temp, Water Temp, Open/Closed Loop and MPG or Ignition advance.
I have other gauges for Voltage and Boost.
Old Aug 5, 2008 | 05:32 AM
hopper's Avatar
hopper
Sounds like my inital setup is pretty consistent with what people watch. I guess the next question becomes how to interpret the closed/open loop and MAP data. Can this be used to get maximum fuel ecconomy on the highway? Is it even valid with the Alta PnP ECU?
Waszak
Oct 21, 2017 05:55 PM
Hippiehobbit267
Sep 1, 2015 06:13 PM
shark715
Aug 30, 2015 07:01 PM
minipopkart
Aug 13, 2015 05:22 AM
MES11
Aug 8, 2015 10:21 AM
