Electrical problem with ALTA Boost gauge
Old May 13, 2008 | 12:05 PM
joshK's Avatar
joshK
after a couple of month of working fine, my Alta boost gauge took a crap today. The water temp gauge still works but the boost gauge is flashing red and reads a constant 30 psi (gauge max) even at idle. Nothing has been changed on the car since these were installed. Anyone have any idea what the problem could be? Did I just get a defective gauge?
Old May 13, 2008 | 01:31 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
did the gauge start to make any grinding noises on start-up before it quit?
Old May 13, 2008 | 01:35 PM
joshK's Avatar
joshK
not that I remember. The gauge still goes through it's normal startup process but once the startup process is over the needle goes up to 30 psi and stops.
Old May 13, 2008 | 03:22 PM
Xray'dit_Mini
I bet the sending unit has gone bad (the little box that converts the vacuum line into an electrical signal). If you unplug the sensor for the water temp gauge and then start the car the water gauge will react in the same way as the boost.
Old May 13, 2008 | 03:31 PM
joshK's Avatar
joshK
ah...good to know. Someone from Alta has already returned my email so it seems as though it will get taken care of quickly :0)
Old May 13, 2008 | 06:28 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Sorry about the inconvenience! We have had a couple of these go bad, but have gotten em fixed ASAP! Let me know if there is an issue!
silence2-38554
98
Sep 21, 2016 02:52 PM
AWOL
Mar 28, 2016 10:51 AM
wkp1219
Nov 13, 2015 07:52 AM
stierzy34
Sep 15, 2015 04:40 PM
