Electrical JCW / Mini Accessory for Temp / Electrical Gauges
Old Dec 23, 2008 | 08:25 AM
kbleicher's Avatar
kbleicher
Hi there,
I'm really bummed that I don't have temp / electrical gauges on my Clubman. I didn't really think about it until the weather got cold. I'd love to know what the engine temp is so I don't fire it up too soon in the frigid weather.
When I was ordering my Clubman I thought I saw some gauge add-ons that would mount on either side of the tach on the steering column. Hopefully it'd be an add on at the dealership; if it's too involved I won't be able to do it (though I can do some work myself).
Am I imagining things? Is there a solution that blends in with the look of the current instrument cluster?
Thanks!
Old Dec 23, 2008 | 10:41 AM
schatzy62's Avatar
schatzy62
There are numerous aftermarket options.
Chekc out the following
outmotoring.com
AltaPerformance.com
coopersport.com
cravinspeed.com
and others in the Vendor Directory.
Old Dec 23, 2008 | 11:23 AM
Loony2N's Avatar
Loony2N
Easy: ScangaugeII. Plugs right into the OBDC socket, gives temp, volts, boost, engine load, etc. and fits perfectly into the center cubby. Looks like it belongs there. Of course, it's digital, but so are most "guages". Also, the orange background color (which is selectable) matches the Mini's.
Old Dec 23, 2008 | 11:54 AM
kbleicher's Avatar
kbleicher
Thanks for the replies... Sounds good
I'll take a look at these. I thought I saw an option, perhaps under JCW in terms of an offering during the order process, but I must be remembering wrong....
Sorry for posting something that may already be out there; I did a search first and it wasn't clear....
Old Dec 23, 2008 | 01:52 PM
scottab36's Avatar
scottab36
www.scangauge.com will set you up with temp, electrical, Air inlet temp and a whole lot more!
Old Dec 23, 2008 | 05:10 PM
Minidrivr's Avatar
Minidrivr
Scanguage is about the cheapest and easiest solution if you don't mind not having a round gauge.
Pics in my gallery.
Old Dec 27, 2008 | 08:49 AM
pilotart's Avatar
pilotart
+++ (ScanGauge website HERE)
click HERE for a large photo, easiest install you could imagine and comes with all you need,
including velcro adhesive strips (you can see the edges at top and bottom).
Powered by your OBD II Port; it is amazing all the information and recording that is available.
To download a PDF of the Manual, click HERE.
Old Dec 28, 2008 | 06:07 PM
kbleicher's Avatar
kbleicher
Wow.. thanks again everyone. Very good info!
Dec 23, 2015 10:36 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
