Electrical Hella 500 Wiring
Old Jan 24, 2009 | 01:20 PM
Kazy's Avatar
Kazy
Hella 500 Wiring
Could anyone tell me how to hook up the relay to get them to turn on with the high beam only without any other switch?
I opened everything up, but I had to give up and put it all back together again because I couldn't find the wire to splice it into.
It says "Connect to high-beam wire", but I have no idea which one is the high beam wire.
They're all black and the only difference is the "A" "B" and "C" markings.
Could anyone post how they have their Hella 500s wired up? Pictures would be helpful, and please please please R56 only. I've looked through the R50/R53 threads and they seem to be too different to help.
Old Jan 24, 2009 | 01:33 PM
Eurothrasher's Avatar
Eurothrasher
Not sure if this is R53 or not. Maybe you can tell.
Also, at one time, the side of the relay itself had a half **** wiring diagram on it. Do they do that anymore?
Old Jan 24, 2009 | 01:39 PM
Kazy's Avatar
Kazy
I have the paper that came with the Hella 500s, but i don't knnow which wire is which on the headbeams on the MINI, which is what I was asking.
Old Jan 24, 2009 | 01:59 PM
Eurothrasher
if you cant find a diagram you will have to check the wires yourself with a Hot wire tester that has a bulb built into handle and a pointed tang on the end. Turn high beams on and push the pointed end into one of the wires going to the headlights. When the light in the handle comes on, turn off high beams to low beams - If the the light in the tester handle goes out as well, you have the correct lead from high beam.
Autozone's have these for about 6 bucks. Works great, my tool box has always had one for last 25 years, or sometimes I have had to just make my own with a turn signal bulb and some wire.
To circumvent the switch, I think you only have to put a jumper wire as in diagram ? The only problem is that they will always come on with high beams - so you will not be able to use the lens covers that came with the lights.
Basically the power from the HD lights closes the circut of the relay, not the aux lights themselves.
Old Jan 24, 2009 | 07:07 PM
Kazy's Avatar
Kazy
Thanks, that was just the info I needed.
Hopefully I'll get this done soon.
Old Jan 28, 2009 | 06:47 PM
digi0123's Avatar
digi0123
well? work? no? pics?
Old Jan 28, 2009 | 07:48 PM
Motor On's Avatar
Motor On
+1, I was looking to help you out, but the R56 where to tap is the one part about this that I'm unsure of, but is critical for installing any aftermarket driving lights. If you still don't know there is one R56 thread on here and one other website that I might be able to go dig up an answer for for you.
Old Jan 29, 2009 | 11:57 AM
Kazy's Avatar
Kazy
Well, I'm up at college and I won't be able to work on it until Saturday probably.
edit: My dad's been helping me as well, but he's back at home and I won't be home until Friday evening, hence the Saturday thing. Any extra help in the meantime would be very much appreciated though.
Old Jan 29, 2009 | 07:48 PM
Motor On's Avatar
Motor On
I found the original MINI R56 retrofit instructions
Which seem to talk about a yellow/blue wire (yellow w/ blue stripe) but am as of yet unable to find the wire you are looking for
Old Jan 31, 2009 | 01:32 PM
Kazy's Avatar
Kazy
Got 'em working! Turns out the terminal marked "C" held the high-beam wire. We used those stripless splicers from Auto-Zone to hook everything up, so now they come on with the high-beams!
Old May 17, 2009 | 06:22 PM
h20polo93's Avatar
h20polo93
so im assuming that the B marked one would be the low beams right??
Filmy
15
Jun 6, 2023 06:27 AM
nashvillemini
Sep 30, 2015 10:26 PM
atlantaorange
Sep 16, 2015 12:43 PM
Filmy
Sep 7, 2015 08:27 PM
