Electrical Anyone have an oil temp guage in their R56?
Old Jul 21, 2008 | 03:05 PM
gmhl10's Avatar
gmhl10
I wanted to install an oil temp and water temp guage on the car with the Alta pods (Don't really think boost guage would be helpful since I don't plan on changing the boost pressure).
What sensor should I use to install the oil temp guage and where can I find it?
I remember on my old 2002 BMW 325i, I used an oil temp guage that was connected to the oil drain plug... anything as simple as that?
Old Mar 27, 2009 | 03:05 PM
masterd78's Avatar
masterd78
MANIAC
No Oil Temp solution yet???? Come on someone!
Old Mar 27, 2009 | 03:53 PM
AkFarina's Avatar
AkFarina
drill a tap on top of the filter container
Old Mar 27, 2009 | 06:58 PM
schatzy62's Avatar
schatzy62
e-mail Craven Speed http://www.cravenspeed.com
Iknow they have an adapter for the R-53. I am not sure about the R55/56
Old Apr 3, 2009 | 12:43 PM
M3This's Avatar
M3This
I would like to know as well as I want to run a oil pressure gauge as too me oil temp and water temp are relative to one another, so if you have one you really dont need the other.
Old Apr 4, 2009 | 09:15 PM
masterd78's Avatar
masterd78
MANIAC
M3this, then why don't you just throw a water temp gauge in there and be done with it. Easy install.
Old Apr 6, 2009 | 12:35 PM
M3This's Avatar
M3This
I plan on doing Water Temp and Oil Pressure as when on the track those are the two most important things to watch, as if the motor is running too hot you need to stop or if you loose oil pressure you need to spot immediately.
Old Apr 6, 2009 | 04:17 PM
scottab36's Avatar
scottab36
For the water temp plus a lot more:
www.scangauge.com
Old Apr 6, 2009 | 11:07 PM
Grassroots Garage's Avatar
Grassroots Garage
I am working with CravenSpeed on an oil pressure tap, we should see it soon. If any of you are interested, send me a note...e-mail from my webiste works best. I'll set up a list and get with you when they are ready.
I do not recommend drilling into the oil filter cap, there is not much material there, and you're just asking for trouble
--Dan
Old Apr 6, 2009 | 11:22 PM
Eric_Rowland's Avatar
Eric_Rowland
The OEM Auxillary gauges use a drain plug temp sender.
On the downside, it only has three friggin' threads, and my 'only changed by the dealer and myself' MCS puked the three threads in the AL oil pan after 40K+ miles.
Old Apr 7, 2009 | 09:30 AM
Grassroots Garage
LOL...I totally misread the title of the post. I prefer to watch water temp over oil temp, however for track use, oil temp is important on a turbo.
I'm baffled as to why they would use a temp sender without enough treads
Old Apr 7, 2009 | 02:04 PM
AkFarina's Avatar
AkFarina
you could drill a tap in your oil pan
Old Apr 7, 2009 | 03:36 PM
Grassroots Garage
That has worked well for me on the W11 engine with the aluminum oil pan, but the N14 is stamped. Either way, the pan should be removed and a bung should be welded to the pan. The sensor in place of the drain plug is ideal, but finding one that actually fits with the right Ohms range will be the trick.
Old Oct 10, 2011 | 02:44 PM
Performance Angst's Avatar
Performance Angst
How hard would it be to R&R the oil pan with the engine in the car to drill and weld a bung to it for the oil temp sensor?
Old Oct 10, 2011 | 03:24 PM
DneprDave's Avatar
DneprDave
I used Craven speed's tapless adapter, for their oil pressure sender, but instead of connecting the oil pressure sender directly to the tapless adapter, I screwed a two foot length of 1/4" hydraulic hose into the adapter and remotely mounted the oil pressure sender. That left enough room for a temperature sender to be screwed into the tapless adapter too. Be sure to bleed the air out of the adapter or the temperature reading will be erratic.
Dave
Old Oct 10, 2011 | 03:37 PM
countryboyshane's Avatar
countryboyshane
Dave
Wait, so you have two feet of hose hanging in your engine bay filled with pressurized engine oil?
Old Oct 10, 2011 | 04:32 PM
DneprDave's Avatar
DneprDave
Yep! It is hydraulic hose rated at 5000 psi.
I'm not worried that the the 60psi that the MINI's oil pump produces is any threat to the hose's integrity.
Hydraulics companies will put together any kind of hose, with any kind of fitting you want, for a reasonable price.
Dave
Old Oct 10, 2011 | 06:16 PM
2009R56JCW's Avatar
2009R56JCW
My headunit displays oil pressure,oiltemp,watertemp,air/fuel ratio,boost pressure and ignition timing.
Old Oct 10, 2011 | 06:49 PM
Performance Angst
Dave
I have no concerns with the pressure but the I would think the ability of the oil to circulate and render an accurate temp reading would be hindered by a long run of small diameter hose.
Old Oct 10, 2011 | 06:56 PM
2009R56JCW's Avatar
2009R56JCW
delete
Old Oct 10, 2011 | 09:06 PM
DneprDave's Avatar
DneprDave
The oil temperature sender is not at the end of the hose, it is screwed into the tapless adapter, next to the head. The pressure sender is at the end of the hose.
The reason for bleeding the air out of the adapter is so that the sender is immersed in hot oil, not in an air bubble.
With the variations in oil pressure and different RPMs, hot oil pushes in and out of that inch of adapter frequently, heating the temperature probe to the oil temperature. The gage stays steady.
Dave
Old Oct 11, 2011 | 06:25 AM
Performance Angst
Dave
Thanks for the additional info. I thought the oil temp sender was at the end of the hose looking at the pic. That adapter is looking like the best option at this point. My other option would be to pull the oil pan and weld a bung on it. Not sure if the pan can be removed with the engine still in the car.
I've got the oil drain pug adapter but, I don't like the idea of removing the sensor to drain the oil.
Kimolaoha
Jul 5, 2023 01:04 PM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
Lex2008
Aug 16, 2015 08:33 PM
