Electrical Keeping Aux light button on all the time?
Old Aug 11, 2008 | 01:49 PM
clnconcpts's Avatar
clnconcpts
How can i get the Aux driving lamps button on dash to stay on?I hate having to hit the button every time i click the high beams on.Every time i have to turn brights off and then turn back on,I must click that button on right side of dash back on..I hate this.How can i fix this silly issue?
Old Aug 11, 2008 | 02:51 PM
schatzy62's Avatar
schatzy62
If i understand you correctly you mean that when you have the Aux Driving Lights on and then switch to high beams the Aux Lights go off. Then when you go back to regular (not high beams) you have to turn the Aux lights back on Manually.
If this is the case then see the dealer if they installed them as they should come back on when returning to regular beams (not high). As for them going off when you go to high beams that is the way they are supposed to work and they should not even be able to be on when in high beam mode. The law states that when switching on high beams the fog or driving lights must go off. The thing is that they should come back on when turning the high beams off.
Old Aug 11, 2008 | 03:20 PM
Minidrivr's Avatar
Minidrivr
clnconcpts, are you talking about the OEM driving lights? The ones with the button to the left side of the steering wheel on color line?
They work with the high beams on my car. That switch is a toggle that remembers the setting. If I have the high beams on, turn on the driving lights, and then turn off the high beams, the driving lights turn off. Then next time I turn on the high beams, the driving lights turn on with them. The switch on the dash has a small green LED that tells you when they are on.
Old Aug 11, 2008 | 03:25 PM
clnconcpts's Avatar
clnconcpts
On mine that little switch on the dash turns off when i go back to low beams and when i turn high beams back on- I have to hit that switch so the AUX driving lights come back on.
Old Aug 11, 2008 | 04:14 PM
Minidrivr's Avatar
Minidrivr
Ok, I'll re-check mine just to be sure next time I drive the Mini. I don't remember mine being that way at all.
Does the green light go out after your turn off the high beams? The green light on mine stays with the switch pressed in, even without the high beams turned on.
Old Aug 11, 2008 | 04:19 PM
clnconcpts's Avatar
clnconcpts
Mine turns off.Pisses me off.Mine must be wired funky,then.
Old Aug 11, 2008 | 05:24 PM
ScottRiqui's Avatar
ScottRiqui
Definitely have the dealer check it out. It's not uncommon for the aux driving lights to be wired incorrectly. On both of our MINIs, they can be turned on with either the high beams or the low beams, which I know is wrong.
Old Aug 11, 2008 | 06:38 PM
jw34's Avatar
jw34
From the official MINI Driving light install instructions:
Old Aug 11, 2008 | 07:07 PM
clnconcpts's Avatar
clnconcpts
Not in my case.The light goes off as soon as i click back to the low beam function
Old Aug 18, 2008 | 10:14 AM
Minidrivr's Avatar
Minidrivr
clnconcpts, any update?
I rechecked mine over the weekend. The driving lights never turn off until I push the switch again. Using the high beams doesn't reset them to off once you go back to the normal beam.
Old Aug 18, 2008 | 10:21 AM
clnconcpts's Avatar
clnconcpts
My button light turns off when i click high beams off.Still have to re-push button when i click high beams on
Old Aug 18, 2008 | 02:21 PM
Minidrivr's Avatar
Minidrivr
I would contact the dealer. That is definitely not the way it's supposed to be working.
TREX
Nov 2, 2019 07:31 PM
tippin
Aug 5, 2015 08:43 AM
nismo4life
Aug 5, 2015 08:31 AM
