Electrical Electrical Diagram site!
Old Sep 20, 2008 | 12:40 PM
mysticturner's Avatar
mysticturner
This need to be set as a sticky in this forum! Bob posted this web address on another thread ("What fuse should I tap in an R56?") that I just found. It's a site that contains the electrical diagrams for MINIs! It requires the use of Internet Explorer (I normally use firefox and had problems) with an extension from Adobe called SVG.
http://www.mcaw.info/wds/mini/us/r56/index.htm
I didn't go exploring there but it looked like it might have 1st Generation diagrams as well. It takes a couple of hours to get used to but well worth the time if you want to make electrical mods to your MINI!
Thanks Bob! (aka K6rtm)
Old Sep 20, 2008 | 02:28 PM
Minidrivr's Avatar
Minidrivr
Yep, it's been floating around the site for a while now. Sticky is a good idea.
Or better yet, you can download the entire archive of the site if you navigate back on the web address a bit. The server has the zip file there too. Then you can run it locally on your system without a net connection.
Old Sep 22, 2008 | 08:14 AM
schatzy62's Avatar
schatzy62
Only problem is, we the general public are not supposed to have access to it. Only dealer and authorized repair stations. SO making it a sticky puts it out there to be seen that much easier and could possibly get it protected more than it is .
SO i would say No on the sticky part but do make a bookmark to it.
Old Sep 22, 2008 | 12:36 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Pssst.
Consider the availability of this site as a 'gift of goof'. Use it sparingly and dont post it everywhere. As the above poster has stated, it was not meant for the general population, and proliferating access and downloading the entire contents will cause it to be locked down by the site operators. It wont be made sticky as a result.
Old Sep 22, 2008 | 05:16 PM
schatzy62's Avatar
schatzy62
Actually can we get rid of this thread as it is stated in the title what it is about.
Old Sep 22, 2008 | 06:00 PM
Minidrivr's Avatar
Minidrivr
Good thinking guys. Although if you go to the main part of the address, you sure aren't at a BMW service site. I'll stick to the downloaded version.
USNAE2
16
Jun 17, 2022 07:17 AM
chowpott
Oct 19, 2015 08:37 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
