Electrical Auto open sunroof?
Old Feb 9, 2009 | 11:13 PM
ThumperMCS's Avatar
ThumperMCS
Auto open sunroof?
I haven't been in this section forever..but has anyone figured out a way to make the sunroof open with one touch like it used to be in the R53??
Honestly so simple and dumb but its one of the biggest annoyances for me with the R56!
Old Feb 10, 2009 | 09:19 AM
schatzy62's Avatar
schatzy62
Do a search and you will find that there are a number of threads on this subject and BTW no one has found a way to auto open all the way back.
Auto open only works for the double raised function.
Old Feb 10, 2009 | 11:20 AM
Whisky B's Avatar
Whisky B
wow
That sounds crazy, the one on my 2005 opens all the way if I slide the button backward (as if to open it regular) and hold it to the rear momentarily before releasing. Doing that should pop the roof open and the rest should be automatic. Hope this helps, I don't think Mini would change that feature on 08's.
Old Feb 10, 2009 | 11:30 AM
MoxieMini's Avatar
MoxieMini
They did. My 09 MCS doesn't auto open. It's annoying as all hell.
Old Feb 11, 2009 | 01:04 PM
schatzy62's Avatar
schatzy62
On the Second Gen Mini's
One press to open to the double tilt
Press and HOLD until it is open all the way
Press and HOLD to Close from full open
Press and HOLD to Close from Double Tilt.
Old Feb 11, 2009 | 03:51 PM
Whisky B's Avatar
Whisky B
Interesting, the momentary hold works for both opening and closing the roof on the ol' Jet Black. What the hell are they doing over there in Germany
Old Mar 22, 2009 | 11:20 PM
DrkSilver163's Avatar
DrkSilver163
Is there a reason that nobody has made one yet? Id consider trying if it is possible...Unless theres a reason you cant.
Old May 19, 2009 | 07:47 AM
hardingsan's Avatar
hardingsan
any movement on this? i'm not electrically inclined, but if someone made one that worked i'd buy it for sure...
Old May 19, 2009 | 08:19 AM
Carlisle's Avatar
Carlisle
I am thinking there must be a website SOMEWHERE that sells a flash module that you use once to program this feature.
I found one for my VW New Beetle (2006 TDI) that I used once to flash the ECU, then my key fob worked to open AND close the windows with one touch of the lock or open button! This was great for when you forgot to put up your windows but had already taken the key out!
I think I got it at ECS tuning... they sell BMW parts but no MINI parts sadly... I bought it for $50 or so if I recall...
Old May 21, 2009 | 05:17 AM
hardingsan's Avatar
hardingsan
i sent an email to ECS Tuning asking if they offered anything for the kit. they said they didn't have anything, but the wiring should be similar to the wiring in BMWs and sent me this how to link. anyone brave enough to be a guina pig...?
http://www.bmwe36blog.com/2008/11/23...e-sunroof-diy/
Old May 21, 2009 | 06:48 AM
schatzy62's Avatar
schatzy62
That part is not going to work.
The E36 BMW was manufactured from 1991 to 2000 and had some but not alot of computer control.
All of the Mini's Functions are computer controled by one module or another.
Also on the E36 BMW the power for the sunroof went to a single pole switch and then on to the sunroof motor. The motor opened the sun roof or closed the sunroof.
In the Mini there is a 3 pole 4 position switch. The switch position dictates tot he electronics control module in the sunroof takes.
I would suggest that no one try that part as they will damage the sunroof control module. The sunroof control module has 12 VDC input but it is not a switched line, it is on all the time. All the control functions are done by low level control signals depending on the position of the switch. There is also a connection to the CAN bus for control by other items such as the Car Access System. I.E. there is a mini computer in the sunroof control module that handles all the fuctions not a 12 VDC switch.
Now can this be changed by programing - Probably but to get mini to release the info needed and getting someone to do it will be every expensive.
Old May 21, 2009 | 06:56 AM
hardingsan's Avatar
hardingsan
oh, good looking out. not trying to blow up anyone's sunroof, just passing on some information i've puled out of a vendor. i though it would help the discussion along...
Old May 21, 2009 | 09:28 AM
Carlisle's Avatar
Carlisle
I'd actually just love to have the "dial a position" sunroof style that VW/Audi uses. Far superior than a swtich or button in my opinion... but then again... I do love the toggles!
Old Jun 7, 2009 | 08:01 PM
JIMINNI's Avatar
JIMINNI
+1 since we now own a R53 and a R56, it's really annoying.
Put me on the list to buy one I know someone is making one touch up/down modules for R53 windows, anyone know who it is?
Old Jun 9, 2009 | 03:05 AM
schatzy62's Avatar
schatzy62
See this thread, I do not know why they had to open a new thread for this but they did.
https://www.northamericanmotoring.co...r-the-r56.html
Old Jun 14, 2009 | 07:11 PM
Pierson's Avatar
Pierson
http://www.youtube.com/watch?v=eC61kyusc98
Old Jun 15, 2009 | 08:02 AM
JIMINNI's Avatar
JIMINNI
Originally Posted by Pierson
Where do you buy that?
Old Jun 15, 2009 | 09:47 AM
schatzy62's Avatar
schatzy62
Did you read the post two up from yours or one up from the one you quoted.
It has all the info in it that is available at this time. Tey are not actually in production yet but will be soon.
Here again is the thread posted that has the info.
https://www.northamericanmotoring.com...r-the-r56.html
Old Jun 15, 2009 | 11:40 AM
JIMINNI's Avatar
JIMINNI
Old Jul 12, 2010 | 08:52 AM
jbourne's Avatar
jbourne
The thread linked seems to be dead, but highly intereted if there was ever a solution to this.
Also - auto-up/auto-down windows on a 2009 Cooper S hatch. What gives, why absent?
Old Jul 12, 2010 | 09:20 AM
DrkSilver163
Outmotoring has this for sale:
http://www.outmotoring.com/mini-coop...en_module.html
As for the auto open and close windows, my 2009 has them. Not sure why another one wouldnt.
Old Jul 12, 2010 | 09:25 AM
jbourne's Avatar
jbourne
I'm going to have to check. My 2009 is still in delivery, so once I get it I will see.... I forgot to check that when I was test driving it :( so maybe I am panicking for no reason, hehe.
Old Jul 12, 2010 | 06:26 PM
slimjimtell's Avatar
slimjimtell
You can get a one touch OPEN/CLOSE sunroof module from...
http://www.kptechnologies.com/
it is the ITEM#MO20 for 49.99
I put one in my 2010 Clubman and it works like a charm.
Old Jul 16, 2010 | 05:34 PM
kukaepe's Avatar
kukaepe
Got one from Outmotoring for my '07 MCS and it works wonderful. Engine needs to be running but other than that it works great. I find that I use the sunroof more now that it's just a double tap on the switch to open or close.
Filmy
15
Jun 6, 2023 06:27 AM
patsum
26
May 29, 2021 06:29 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
